What size disk?
/ What size disk? #1
Springdrl
How should I determine what size disk I can attach to my 23hp tractor? It will be used to create food plots for deer.
Thanks.
/ What size disk? #2
I wouldn't go bigger than a 4' disk.
/ What size disk? #3
I think you could probably pull a 4' heavy duty or a 5' light/medium duty. I've used a 2wd 29 hp to pull a 6' medium duty. If it doesn't pick your front end up when you pick it up, you could probably go 5', especially if you have 4wd.
/ What size disk?
Thanks for the feedback. I was thinking too that any disk that doesn't lift the front wheels when you pick it up is probably going to work.
/ What size disk? #5
5' light duty with a 200+# weight is all my L2500 can handle(26hp). Depending on the soil the disk will bury the tractor. But it's a catch 22, untouched ground and you need a heavy disk to cut. To heavy and it's to much for the tractor. Shipping weight on a disk like mine is 500#, my FM is 525#. With my tractor a 4' is not wider than the rear wheels.
If you can use a 1-2 row subsoiler to break it up then disk. Search for some of my recent posts on my disk, subsoiler and plots. All I need for my plots is some water.
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
7'x12' Trailer (A64127)
7'x12' Trailer...
2023 Kubota L2501HST (A64126)
2023 Kubota...
