Chains What size chain would you recommend to drive a 60" snowblower
   / What size chain would you recommend to drive a 60" snowblower #1
Malachi Raymond
Northern Michigan
Mahindra 1526
Not sure what size chain I should use thanks for your help
   / What size chain would you recommend to drive a 60" snowblower #2
Both of my blowers are 78" wide and the auger chain is #60 size roller chain... I see #60 used on a lot of 60" blowers for the auger, too. If you are driving the fan via chain, #60 would be plenty strong.. but you should still use an appropriate smaller size shear bolt/pin as if you were driving it via a PTO shaft. This would be to protect the tractor gears.
   / What size chain would you recommend to drive a 60" snowblower #4
Make sure your sprocket's all are the same pitch (#) as the chain.
   / What size chain would you recommend to drive a 60" snowblower #6
For what it is worth, I've owned a 60" (forgot the manuf.) and 63" blower (Kubota) and both used #50 chain. The 72" Kubota blower uses #60.
Thanks you guys for the info, just what I was looking for👍
New Holland T5060 Tractor (RIDE AND DRIVE) (A50774)
New Holland T5060...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2015 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
VERMEER 605F ROUND HAY BALER (A51243)
VERMEER 605F ROUND...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
