Chains What size chain would you recommend to drive a 60" snowblower
   / What size chain would you recommend to drive a 60" snowblower #1
Malachi Raymond
Northern Michigan
Mahindra 1526
Not sure what size chain I should use thanks for your help
   / What size chain would you recommend to drive a 60" snowblower #2
Both of my blowers are 78" wide and the auger chain is #60 size roller chain... I see #60 used on a lot of 60" blowers for the auger, too. If you are driving the fan via chain, #60 would be plenty strong.. but you should still use an appropriate smaller size shear bolt/pin as if you were driving it via a PTO shaft. This would be to protect the tractor gears.
   / What size chain would you recommend to drive a 60" snowblower #4
Make sure your sprocket's all are the same pitch (#) as the chain.
   / What size chain would you recommend to drive a 60" snowblower #6
For what it is worth, I've owned a 60" (forgot the manuf.) and 63" blower (Kubota) and both used #50 chain. The 72" Kubota blower uses #60.
Thanks you guys for the info, just what I was looking for👍
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
1994 WABASH 102" X 53' T/A VAN TRAILER (A51243)
1994 WABASH 102" X...
2003 DITCH WITCH 3700 RIDE ON TRENCHER (A51242)
2003 DITCH WITCH...
Deere 304K (A50120)
Deere 304K (A50120)
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F-450...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
