Chains What size chain would you recommend to drive a 60" snowblower
   / What size chain would you recommend to drive a 60" snowblower #1
Malachi Raymond
Northern Michigan
Mahindra 1526
Not sure what size chain I should use thanks for your help
   / What size chain would you recommend to drive a 60" snowblower #2
Both of my blowers are 78" wide and the auger chain is #60 size roller chain... I see #60 used on a lot of 60" blowers for the auger, too. If you are driving the fan via chain, #60 would be plenty strong.. but you should still use an appropriate smaller size shear bolt/pin as if you were driving it via a PTO shaft. This would be to protect the tractor gears.
   / What size chain would you recommend to drive a 60" snowblower #4
Make sure your sprocket's all are the same pitch (#) as the chain.
   / What size chain would you recommend to drive a 60" snowblower #6
For what it is worth, I've owned a 60" (forgot the manuf.) and 63" blower (Kubota) and both used #50 chain. The 72" Kubota blower uses #60.
Thanks you guys for the info, just what I was looking for👍
2015 Dodge 5500 4X4 Bucket Truck (A52128)
2015 Dodge 5500...
TRAILER AXLE (A51244)
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2016 CATERPILLAR 257D SKID STEER (A51242)
2016 CATERPILLAR...
1963 Trail Mobil Tanker (A50514)
1963 Trail Mobil...
International 1420 Combine (A50514)
International 1420...
