what size chain for guard??
/ what size chain for guard?? #1
Dmax
ARKANSAS
KUBOTA M6800SDC
what size chain is used on rotary cutter guard?? Where is the cheapest place to buy it?
Thanks
/ what size chain for guard?? #2
Are you looking to put short lengths of chain along the edge of your cutter to stop material from flying out while cutting?
If so, then you don't kneed a very high quality chain or much strength. Weight is more important for stoping then it is for holding.
I've found the lowest price on low quality chain at Wal-Mart. I wouldn't use it for dragging a tree, but it's fine for a quick gate or dog collar.
/ what size chain for guard?? #3
I found the chain I used for my tractors bar chains at Menards.3/16 and the links are about an inch long.$12.99 for twenty feet.If you cut the end of the link and use that end to weld it into place you would have zero loss.
/ what size chain for guard?? #4
I used 5/16th chain on mine. /forums/images/graemlins/grin.gif
Here's how I made my "choice". /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
About 10 years ago, I rolled into the parking lot at work one morning. I noticed "something" strung across the lot. I walked in the office, turned off the alarm, and turned on the lights.After I had my morning "constitutional", I walked outside. Lo and behold! /forums/images/graemlins/shocked.gif What was strung across the lot was a piece of 5/16th inch chain, at least 200' long. It had a fence post at each end, and a big ol' padlock fastened to one fencepost. I'm just guessing, but it looked like what you would expect to find enclosing something like a used car dealers lot. It had been dragged on the street. A good many of the chain links were worn shiney from being dragged. I watched the classifieds for a few day to see if anyone was missing a 200' chain. No "lost chain" adds...... /forums/images/graemlins/crazy.gif
I use "Grade 70 binder chains" on my trailer to secure loads. This old stuff is nowhere near D.O.T. standards. It is just "utility chain". /forums/images/graemlins/wink.gif
Do you have any clue as to how long it takes to use up 200' of chain????? /forums/images/graemlins/confused.gif /forums/images/graemlins/tongue.gif
So far, I've made 3 sets of "saftey chains" for bush hog mowers... I'm down to about 80'.............. /forums/images/graemlins/grin.gif
/ what size chain for guard?? #5
I think the size of the chain depends on the size of the cutter; 3/16" on the smaller (3-point cutters) up to 3/8" on some of the larger (batwing) cutters.
/ what size chain for guard?? #6
I think mine are 3/8" links. They might be 5/16 though, I don't remember. I'll have to measure them and see.
Attached is a picture of what the front of my cutter looks like...it is a Woods BB60.
Like EddieWalker said above, heavy would be better than light...
Edit: I checked those chains...looks like they are 5/16... /forums/images/graemlins/smile.gif
/ what size chain for guard?? #7
I was looking at my buddies and his had the rod through the chain passed with the chain passed through a slot in angle iron setup like Henro's.
I thought that was really neat, and thought about duplicating it till I thought about cutting all those slots.
Now I am back to the flat strap idea, and just welding the chain on it flat and bolting it too the rotary cutter.
My question is, do you ever have to change those chains? I can cut them off and weld on a new one, but it would not be as nice as sliding out that rod and replacing bad ones. I have no experience with that, but I doubt that those chains wear out or break very much. Or do they?
/ what size chain for guard?? #8
I did the rear chain guard on my BB840 with a 1/4" X 2" flat bar, and then welded the chains to it. (By the way, it took 112 pieces of chain to reach around that 7' radius) From time to time, I've knocked a few of 'em off. (Hitting "stuff" while mowing) I've probably replaced 6 or 8 pieces of chain. I just grind the spot clean, and weld away... /forums/images/graemlins/tongue.gif /forums/images/graemlins/smirk.gif
At the rate I'm wearing them down, it would take YEARS, if not decades to wear out a chain link dragging them through the grass. /forums/images/graemlins/grin.gif
One word of caution...!!!!! /forums/images/graemlins/shocked.gif Make certain you don't get the chains even ONE LINK too long. They'll make contact with the mower blades. THEN you have a "Missing Link". /forums/images/graemlins/crazy.gif /forums/images/graemlins/smirk.gif
Think I am going to use 4 inch channel and 5/16 chain. I will post a picture when I get them built. Thanks for all the replys
/ what size chain for guard?? #10
I am going to build some chain guards for my shredder but I have never really seen a shredder with them on it. I saw Henro's picture and get the idea but are they only needed on the front, the front and back, or all the way around? I do commericial shredding and I always grit my teeth when I am going near their houses or cars for fear of sending something through a window or worse.
Also I assume you want the chains as long as possible while not being able to contact the blades?
/ what size chain for guard?? #11
You want them on both the front and rear. You are correct about making certain they don't get into the blades. I built my own guards. On an early attemt, I left the chains ONE LINK too long. It wasn't pretty.....Flying chain links /forums/images/graemlins/shocked.gif /forums/images/graemlins/tongue.gif
I do commercial bush hogging too. I have three tractor/mowers running 6 or 7 months a year. (Knock on wood) In 29 years of business, so far, no "flying projectile accidents". Reason????? I NEVER let a tractor/mower out on a job without ALL guards in place. /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif
There is no such thing as being too safe.......... /forums/images/graemlins/smirk.gif /forums/images/graemlins/wink.gif
/ what size chain for guard?? #12
<font color="blue"> I am going to build some chain guards for my shredder but I have never really seen a shredder with them on it. </font>
Bdog,
Here is a pic of what mine looks like from the back... /forums/images/graemlins/smile.gif
CF Grapple (A64127)
CF Grapple (A64127)
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
YANMAR VIO55-6A EXCAVATOR (A63276)
YANMAR VIO55-6A...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2018 Trail King Lowboy (A63689)
2018 Trail King...
