What Size Battery--Ford 2600
   / What Size Battery--Ford 2600 #1
Taylodp
Pass Christian, Ms
Ford 2600
I have a 1976 Ford 2600 38hp diesel tractor and am trying to find out what type (regular or deep cycle) and size (cold cranking amps) battery I need. Any suggestions?
   / What Size Battery--Ford 2600 #2
We always put 4DLT's in ours.
Terry
   / What Size Battery--Ford 2600 #4
Try NH parts- they list cca and battery types for some of their tractors.
Measure your battery dimensions, where the +, - posts are, look and see if your current battery has the info you want on it. Then it is a matter of looking around. Interstate carries batteries for tractors. Call a dealership and ask if they have a battery in stock for your tractor, get him to tell you the group number and cca. With that info (if you can't find in onlline)- you can go anywhere to buy a battery.
Good luck.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
   / What Size Battery--Ford 2600 #5
Good luck.
4DLT is the correct BCI group number for a 2600 diesel battery. CCA ratings will vary between 800 and 1000. 800 is plenty to crank a 2600.
Edit: I'm the parts manager at a New Holland dealership.
   / What Size Battery--Ford 2600 #6
Yes the 4DLT is the right battery. If you go with a different battery, remember some batteries are too tall and the posts will short out on the hood. A-1 Battery in Gulfport has them in stock.
Gary
   / What Size Battery--Ford 2600 #9
The highest amp hour and highest CCA battery that will squeeze into the battery box. If you run a new 2/00 "ground" cable direct from the battery to a starter mounting bolt. The engine will crank much faster due to less voltage drop.
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
DOOSAN G25...
