What Size Battery--Ford 2600
   / What Size Battery--Ford 2600 #1
Taylodp
Pass Christian, Ms
Ford 2600
I have a 1976 Ford 2600 38hp diesel tractor and am trying to find out what type (regular or deep cycle) and size (cold cranking amps) battery I need. Any suggestions?
   / What Size Battery--Ford 2600 #2
We always put 4DLT's in ours.
Terry
   / What Size Battery--Ford 2600 #4
Try NH parts- they list cca and battery types for some of their tractors.
Measure your battery dimensions, where the +, - posts are, look and see if your current battery has the info you want on it. Then it is a matter of looking around. Interstate carries batteries for tractors. Call a dealership and ask if they have a battery in stock for your tractor, get him to tell you the group number and cca. With that info (if you can't find in onlline)- you can go anywhere to buy a battery.
Good luck.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
   / What Size Battery--Ford 2600 #5
Good luck.
4DLT is the correct BCI group number for a 2600 diesel battery. CCA ratings will vary between 800 and 1000. 800 is plenty to crank a 2600.
Edit: I'm the parts manager at a New Holland dealership.
   / What Size Battery--Ford 2600 #6
Yes the 4DLT is the right battery. If you go with a different battery, remember some batteries are too tall and the posts will short out on the hood. A-1 Battery in Gulfport has them in stock.
Gary
   / What Size Battery--Ford 2600 #9
The highest amp hour and highest CCA battery that will squeeze into the battery box. If you run a new 2/00 "ground" cable direct from the battery to a starter mounting bolt. The engine will crank much faster due to less voltage drop.
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56436)
Magnolia Trailer...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
Buffalo Model #3 Horizontal Angle Iron Roll (A59213)
Buffalo Model #3...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
John Deere 1025R (A53317)
John Deere 1025R...
204158 (A57193)
204158 (A57193)
