What Size Battery--Ford 2600
   / What Size Battery--Ford 2600 #1
Taylodp
Pass Christian, Ms
Ford 2600
I have a 1976 Ford 2600 38hp diesel tractor and am trying to find out what type (regular or deep cycle) and size (cold cranking amps) battery I need. Any suggestions?
   / What Size Battery--Ford 2600 #2
We always put 4DLT's in ours.
Terry
   / What Size Battery--Ford 2600 #4
Try NH parts- they list cca and battery types for some of their tractors.
Measure your battery dimensions, where the +, - posts are, look and see if your current battery has the info you want on it. Then it is a matter of looking around. Interstate carries batteries for tractors. Call a dealership and ask if they have a battery in stock for your tractor, get him to tell you the group number and cca. With that info (if you can't find in onlline)- you can go anywhere to buy a battery.
Good luck.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
   / What Size Battery--Ford 2600 #5
Good luck.
4DLT is the correct BCI group number for a 2600 diesel battery. CCA ratings will vary between 800 and 1000. 800 is plenty to crank a 2600.
Edit: I'm the parts manager at a New Holland dealership.
   / What Size Battery--Ford 2600 #6
Yes the 4DLT is the right battery. If you go with a different battery, remember some batteries are too tall and the posts will short out on the hood. A-1 Battery in Gulfport has them in stock.
Gary
   / What Size Battery--Ford 2600 #9
The highest amp hour and highest CCA battery that will squeeze into the battery box. If you run a new 2/00 "ground" cable direct from the battery to a starter mounting bolt. The engine will crank much faster due to less voltage drop.
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
2017 Komatsu PC490-11 Hydraulic Excavator, S/N A41596, PIN# KMTPC251JHWA41596, Turbo Diesel Engine, (A59076)
2017 Komatsu...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
