What position to leave loader and rear blade when parked
   / What position to leave loader and rear blade when parked #1
kcflhrc
Kansas
2013 John Deere 3032E
Seems I remember that hydraulics should be left with a load on them, meaning bucket left up in the air and not resting on the ground. What about the rear 3 point attachments? I typically leave my rear blade on all the time. So, does it matter? I have been leaving the bucket and rear blade resting on the concrete in my garage. But I'm not sure that's the best practice. Thoughts? I have a 2013 JD 3032 E with the 305 Loader and 6' rear blade.
Thanks
   / What position to leave loader and rear blade when parked #2
I leave mine resting in a lowered position.
   / What position to leave loader and rear blade when parked #3
Left down is the safest position especially if children have access.
Thanks guys, I agree with the safety issue, didn't even think of that. No children around but a few stupid adults come by now and then. I will continue to do what I have been doing and leave them down.
Thanks
   / What position to leave loader and rear blade when parked #5
Both down = safety
   / What position to leave loader and rear blade when parked #6
leave my loader in the down position and any equipment hooked up in the down position.
   / What position to leave loader and rear blade when parked #7
I usually leave both loader and 3PH all the way down, and relieve hydro pressure after shutting off the engine. This way I can check my hydro level before using the tractor the next time. According to my dealer, all implements need to be resting to get an accurate measurement of the hydro oil.
I've never heard that hydraulics should be left with a load on them, but I've never heard that it harms anything either.
   / What position to leave loader and rear blade when parked #8
Bobcat owner's manual states the FEL and the backblade attachments should be lowered all the way to the ground.
Turn off the engine.
Then recycle the FEL levers & 3pt to release all pressure on the hydraulics.
   / What position to leave loader and rear blade when parked #9
^ That's what I do. Be kind to your seals and flex lines and they will thank you by lasting a little longer.
Also, an unused, energized, hydraulic circuit left unattended is a potential trip to the ER waiting to happen.
Hydraulic accumulators in a circuit usually require some sort of bleed down provision to avoid just this kind of situation.
   / What position to leave loader and rear blade when parked #10
dropped and FEL curled in if inside, curled out if outside (so it doesn't collect rain and breed mosquitoes).
2008 Ford F-750 Warren 2,000 Gallon Water Truck (A48081)
2008 Ford F-750...
2017 RAM PROMASTER 2500 CARGO VAN (A50505)
2017 RAM PROMASTER...
(8) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(8) ROLLS OF HD...
UNUSED RAYTREE QUICK ATTACH 48" TRENCHER (A50460)
UNUSED RAYTREE...
UNUSED RAYTREE QUICK ATTACH DRUM MULCHER (A50460)
UNUSED RAYTREE...
2006 Ford F-150 4x4 Pickup Truck, VIN # 1FTPW14V66FB02837 (A48836)
2006 Ford F-150...
