What plow do you recomend
   / What plow do you recomend #1
Rio_Grande
Platinum Member
Well with UTV's being all the rage I took the plunge and finanlly bought ATV,,,, As with me 20 years behind the times.
I recently bought a 97 King quad, It is nothing fancy, and was priced at a point I couldnt turn it down.
So as you gathered by now I am a tight ***. We have been getting some signifigant snow falls lately and while I have tractor, skid steer, I dont like getting them out unless we have SNOW like a foot. So I would like to get a blade for the quad. I dont want to spend a mint (remember I am tight) but I dont want to buy junk. I have a winch on the quad and want the plow to have the capability of being angled.
So what blade would you recomend??
   / What plow do you recomend #2
Bear Force ATV Plows are very nice and reliable. Easy to attach and take off. I am not sure of the cost.
   / What plow do you recomend #3
You can check out mooseatv.com
Also Boss, makes plows for atvs.
You may want to check on Craigslist also..see used ones all the time.
   / What plow do you recomend #4
Well you did say you were cheap!
Look for anything used, cheap, in about a 4-5 foot wide range. Should be minimum 6-12" wider than the ATV. Wider and the blade shoves the machine sideways when angled because an atv is light.
Get your local good buddy, welder, to fab some mounts to the front. Attach winch, start plowing.
Key point, the blade pivots on an a-arm that then mounts to two pivots on your ATV, when fabricating or modifying the a-arm mount to fit your ATV be sure the pivot is level with the ground so the blade pivots left/right and remains flat on the ground. If that center pivot bolt is not perpendicular to the ground when plowing, the leading or trailing edge of the blade will be off the ground when you angle the blade. Not what you want.
I change my curtis plow mount and learned the hard way.
A good welder and you can attach any used plow to anything.
Angle adjustment is up to you. Usually manual for Cheap ATV drivers :laughing::laughing::laughing:.
   / What plow do you recomend #5
Another point: wait until summer time and a used blade will be cheaper. :thumbsup:
And on my old TRX450 Honda with moose blade I had a simple piece of rope attached to the angle release that I tugged on then bumped the blade against the snow bank to change angles.
See, me CHEAP and LAZY!!!
   / What plow do you recomend #6
American Manufacturing makes the Eagle Plow. I have had a couple of them. They seem to be nice people, their plows work well, are well-designed and durable. They are also priced fairly reasonably. I always try to tell folks to keep in mind the Cost to Operate of the plows in question. Many of the really cheap plows are just that, cheap. They have very low initial cost but either do not fit or work well and break easily. Then they are no longer a very good deal. The Eagle Plow, for example, is reasonably priced and will hold up under harder use with good support for cutting edges, etc. Any cheaper than that I am concerned the plow would not be durable enough to offer a good value. There are other similar examples out there from other companies.
John M
   / What plow do you recomend #7
John M
I agree, I put an American Eagle plow on my RTV 500 and it's working great. The plow looks very durable so far.:thumbsup:
   / What plow do you recomend #8
I have a Cycle Country 52" bear force plow for my atv. For the last 8 years though I wished that I had a wider plow, so I just bought a 66" Cycle Country poly X-force plow. I wish that they made these years ago! It's 21" tall instead of 15.5 like most other plows and weighs about the same as my old 52". I always hated that the plows weren't high enough. We get a lot of snow here in the winters, Some people might think that 66" is too wide for an atv, but for the last 18 years I used my brother's atv with a 60" blade to plow out our cabin in Norther Wisconsin. It snowed constantly there (lake effect snow) never had a problem with that size even in the deepest of snow storms.
   / What plow do you recomend #9
vanb, good point. What I have found is that good design and curve overcome width. I have seen 60" plows that a tractor could not handle and 72" plows that an ATV could handle. One common misconception is that plow weight equates to plowing performance. It does not. A snowplow needs to be heavy enough and that's it. Sounds like your example plow is one with a good design and it might be snow-specific, which always helps.
John M
   / What plow do you recomend #10
I love my Boss V-plow - very easy on/off - when off there adaptor plate barely changes the look of the machine. It is expensive and very heavy but will last forever
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
Yanmar YT359 (A53317)
Generac XG8000E Generator (A55973)
Generac XG8000E...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
