what on earth does electricity cost near you?
   / what on earth does electricity cost near you? #901
Who knew the lions share of electricity is distribution and no longer generation?
I can easily see that. Poles and wire aren't cheap. Add in all the technology involved in remote reading and system monitoring, plus the potential replacement parts they need to have on hand. Then the cost of road equipment (those boom trucks ain't cheap either), staffing and training, plus insurance for everything above.
Our power has gone out a few times in recent months due to storms. Those crews get out into the thick of it and have brought our power back in a few hours in the middle of the night while the storm is still happening.
I have no idea what a journeyman lineman makes these days, but I'm pretty sure it's a bit more than minimum wage.
   / what on earth does electricity cost near you? #902
Not trying to be a wise guy, but wood poles, actually are cheap. The absolute cheapest.
Hence, we have so many disruptive outages, which wouldn’t have happened if more money was spent on buried lines
   / what on earth does electricity cost near you? #903
Around here starting is $120k/yr, plus overtime. As they are locally chronically short staffed, the average is $225k-ish.
Then again on the job risks are more than paper cuts...
   / what on earth does electricity cost near you? #904
You should look it up. Im curious..
In NH, a licensed journeyman makes a lot better wage than minimum wage.
   / what on earth does electricity cost near you? #905
Buried lines are great in a subdivision with a few dozen houses. The problem is main lines that carry a high current. That generates a lot of heat and underground lines eventually overheat unless you provide cooling or increase the wire size.
   / what on earth does electricity cost near you? #906
Seriously? Buried lines Can carry a lot more than the power for a few dozen houses.
That’s 😂
   / what on earth does electricity cost near you? #907
Heat to 60 and cool to 80.
Well I thought I had posted more than that quote in this thread, but didn't find it in the first 200 posts..
I've one house in the TVA region.
Our residential rates just climbed again.
There is now a flat monthly rat of $19.58 and then it's $0.11667 per KWH.
Tombigbee’s historic rate increases are set out below
• 10/01/03- 2.31%
• 10/01/05- 1.55%
• 10/01/06- 2.01%
• 10/01/08- 2.46%
• 10/01/09- 1.32%
• 10/01/18- 1.51%
• 10/01/22- 0.50%
• 10/01/23 – 4.0%
• 10/01/24 – 1.5%
With rates like that alternative energy has to be awful cheap, including maintenance.
Thankfully my cost of living increase on my CSRS retirement have far outpaced the rising cost of electricity. Taxes on land are not too bad either.
   / what on earth does electricity cost near you? #908
That’s 😂
You can put any amount of power through and underground line, but the cost goes up drastically as you increase the capacity. The lines have to be larger, the insulation is much more expensive, and a certain point, the lines need to be in some type of conduit that provides cooling.
   / what on earth does electricity cost near you? #909
This area is heavily wooded in some areas and lines cross multiple roads, rivers and streams. Underground ain't happenin'.
   / what on earth does electricity cost near you? #910
The same goes for here. My juice is underground from the pole to the house. I am a full acre back from the road behind an acre of forest.
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
