Oil & Fuel What oil should i use for my l245dt
   / What oil should i use for my l245dt #1
almondjoy1955
au gres michigan
kubota L245DT
My tractor says use 80 weight oil in the transmission. As far as i can tell my transmission and hydraulics all use the same resevoir. I am waiting for my I.T. manual to come in the mail hoping that it will tell me the answers to most of my questions. I have been tempted to use Kubota udt in it but not sure. I don't have any attatchments yet and am hoping that whatever i use will also work for my attatchments. It's an old tractor but in real good shape. It's my first tractor and i am planning on changing all the oils and filters.If there is anyone with an answer it would be greatly appreciated.
   / What oil should i use for my l245dt #3
My L245DT Manual says Kubota UDT Transmission fluid (24 qts). And yes, transmission and hydraulics all use the same reservoir.
   / What oil should i use for my l245dt #4
If it is a 4 wheel drive... I likely says you 'can' use 80 w gear oil in the front axle...
Use UDT in the trans/hydro...
If you do not understand oils and fluids, stick with those recommended by Kubota.
KennyV
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2006 CHEVROLET EXPRESS SERVICE VAN (A58017)
2006 CHEVROLET...
1997 Moxy MT30 Haul Truck (A55272)
1997 Moxy MT30...
Kubota L3560 (A57148)
