What oil for JD 4000 series front axle?
   / What oil for JD 4000 series front axle? #1
Anonymous Poster
Epic Contributor
What type of oil is used in the front axle of the JD 4000 series tractors? The manual shows Hygard oil that meets the J20D standard. Is this the standard JD Hygard low-viscosity hydraulic oil? Thanks.
Steve
   / What oil for JD 4000 series front axle? #2
I can't answer that quest, but read on down in your manual. It usually lists a common fluid type (non-JD brand) that you can use if the JD fluid is not available.
   / What oil for JD 4000 series front axle? #3
Yes Steve, It's the same as the trans fluid (low visc)
Thanks David!
RING 2 STARTS HERE @ 9:15 AM (A57192)
RING 2 STARTS HERE...
2008 Ford F-450 Service Truck (A53422)
2008 Ford F-450...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A55852)
Pallet of...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
