What oil for JD 4000 series front axle?
   / What oil for JD 4000 series front axle? #1
Anonymous Poster
Epic Contributor
What type of oil is used in the front axle of the JD 4000 series tractors? The manual shows Hygard oil that meets the J20D standard. Is this the standard JD Hygard low-viscosity hydraulic oil? Thanks.
Steve
   / What oil for JD 4000 series front axle? #2
I can't answer that quest, but read on down in your manual. It usually lists a common fluid type (non-JD brand) that you can use if the JD fluid is not available.
   / What oil for JD 4000 series front axle? #3
Yes Steve, It's the same as the trans fluid (low visc)
Thanks David!
30071 (A55853)
30071 (A55853)
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
Schulte SBW800 Rock Windrower (A55314)
Schulte SBW800...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
