What oil for JD 4000 series front axle?
   / What oil for JD 4000 series front axle? #1
Anonymous Poster
Epic Contributor
What type of oil is used in the front axle of the JD 4000 series tractors? The manual shows Hygard oil that meets the J20D standard. Is this the standard JD Hygard low-viscosity hydraulic oil? Thanks.
Steve
   / What oil for JD 4000 series front axle? #2
I can't answer that quest, but read on down in your manual. It usually lists a common fluid type (non-JD brand) that you can use if the JD fluid is not available.
   / What oil for JD 4000 series front axle? #3
Yes Steve, It's the same as the trans fluid (low visc)
Thanks David!
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2020 Barreto 20RTK 36in Stand-On Trencher (A49461)
2020 Barreto 20RTK...
2014 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2014 MAGNUM...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
