Oil & Fuel What oil do I use.
   / What oil do I use. #1
skunkhome
I am trying to change the oil in my G5200 and am faced with not being able to find 10w-30 oil in CC (obsolete), CF or CI-4. I know the stuff is made but can not find. All I can find is 15w-40 Rotilla, synthetic Rotilla in 5W-40, or an off brand synthetic in 5W-30. What should I do?
   / What oil do I use. #2
The current API spec is CJ and that will work. Stick with Rotella 15w-40 or Delo 15w-40. You can still find some CI oils but they are being replaced by the CJs.
   / What oil do I use. #3
Welcome to TBN. You will come to see that this site contains a vast amount of info. TBN and all the people here has helped numerous times. I have an older L175 that calls for 10w-30 also. I've been using Rotella 15w-40 for the past 3 years without any problems.
2022 Lonestar (A55973)
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2018 Peterbilt 567 Garbage Truck (A55973)
2018 Peterbilt 567...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
