What oil are you using
/ What oil are you using #1
coupman35
Northen Ontario
Now a L4060 had B2650
What oil are you using in your L4060 just wondering because i have 10w30 left over for my b2650 is that good for the l 4060 .Will i have to good whit other oil.
/ What oil are you using #2
As long as its CJ4 or CK4 It will be fine. Your new tractor requires these oils for the dpf.
I personally use a full synthetic CK4 5w40 oil
/ What oil are you using #4
I'd go with 10w-30 'dino' without hesitation esp for break-in and with your climate. By 100 hrs or so I might consider a 5W-30 if going to synthetic, perhaps a 5W-40 after 3k hrs. Really, the same with 'cheap stuff' if it makes API S'x' spec per the OM.
IMO frequency of oil change usually trumps choice of weight. Modern stuff doesn't always need 15W-40 with tighter tolerances or if low hours. $.02
/ What oil are you using #5
Currently using 5w30 Castrol synthetic bought from VW for TDIs. Plan to check online/locally for 0w30 M1 ESP for next changes for the 2025R and the Isuzu.
Your 10w30 should be fine if for diesels.
Switched to 0w30 M1 ESP the last change on the 2025R.
The oil i have is the semi synthetic 10w30 from kubota .But you use other brand oil does it hurt your warrantte
What oil in the tractor when we get the tractor
/ What oil are you using #8
My new trctor came with 10w-30 and the OM recommended it for my climate. (USDA zone 5)
I just buy motor oil and hydro from the NH dealer.
I also don't do annual oil changes with <30 hrs/yr on each tractor.
/ What oil are you using #9
My 0w30 M1 ESP from Advance Auto just came yesterday. Waiting for the OEM filter from Amazon.
/ What oil are you using #10
I'm running Kawasaki engines on my z turns I've always run Kawasaki oil but in the pass seams like I start getting oil consumption after 600 hours had couple going Thur half quart day I've already got 200 hours on one 350 on one thinking about switching to full synthetic mint of waiting to later or mint not need to anyway
Thought on the matter I've had people tell me 2000 hours and no problems
/ What oil are you using #11
A lot of landscapers run 40 or even 50 weight in their air-cooled Kawasaki engines. I personally run 5w30, but my 36" walk behind only sees about 5 hours of use per week, and I barely notice oil consumption over the course of the season.
My Kawasaki manual states that increased oil consumption will occur with a 30 weight oil, but the highest viscosity they recommend is 40.
/ What oil are you using #12
My small engines (riding mower, push mower, generator) all get B&S Dino 30w and none use any oil between annual changes. The riding mower is a 2014 model with a 17.5 hp B&S used year round (warm climate) and when I’ve pulled the valve cover to do valve adjustments the inside is clean as a whistle.
My tractor (LS MT225E) got Rotella T6 5w-40 full syn at 50 hrs and has been loving it. No oil consumption and it runs quieter with the T6 than it did with the factory fill.
/ What oil are you using #13
Those recommendations for annual changes carry a couple assumptions: 1) dino oil 2) short trips or short running periods that don't properly warm up the engine. These go out the window with synthetics. Can go multiple years. Am on multiple years on the generator and on the Tacoma. These always get warmed up well when used and have synthetic.
/ What oil are you using #14
My oil of choice is chevron.
Just did the 50 HR service on the ls 3140. Delo 400 synblend 10-40 cj-4/ ck rated.
I used genuine Is filters, which I believe are made by donaldson. Topped off the hyd./trans fluid with chevron thf 1000 after changing trans and hyd. Filters. That will be the oil for the 500 hour replacement interval for the hyd./trans fluid also.
/ What oil are you using #16
Carlos, if you're Ok with ordering online why not try Amsoil Small Engine Oils? American company making Synthetic Oils since 1972. I'd use the 10w30 or even the 10w40 if used in really hot conditions. If you are seeing some oil use in your equipment right now that could indicate that the lighter ingredients, of your current brand of oil, are evaporating and could be causing sludge in the engine. Not all oils are created equal, some barely make the minimum standards and fail after a few short hours. Click on the link below and read up on this oil. It's not a car oil but made specifically for hard working small engines. I think that there is free shipping if the order is over $100? I'm in Canada so it's a little difficult to get Amsoil here, but it's worth it to me. Dutchy
/ What oil are you using #17
You gotta think Shell and Cheveron can make oil as good as Amsoil. I think Mystic is a major maker and cant see them saving a lot where they bottle under other labels to try to cheapen it all. Some of these fussy butt car enfines need regular change but lots of them can go real long time. Got a few engines change a time or 2 in the 30 years I had them. Got a couple welders changed twice, maybe 3 times a couple trucks too. The modern oil even the dino is so much better than when it was made in 1974 or earlier.
We serviced them regular when they were new and running the snot out of them and now they are part timers never even consider it and just dont run them out.
/ What oil are you using #18
Tractor, pushmower, roto tiller, pressure washer get T6 5w40, zero turn (kawi) gets M1 15W50.
/ What oil are you using #19
Keep in mind T-6 diesel rated 5W40 oil is notapproved approved for gasoline engines with catalytic converters and may shorten their service life. That's why rotella now sells T6 gasoline oil that is G rated for autos with cats.
I saw T5 semi syntatic diesel is 10W 30 that same as the kubota oil i used in my b2650 and will use in my L4060 .
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
FLAT BED (A65643)
FLAT BED (A65643)
