Rear Finish Mower what mower/rotary do you recommend
   / what mower/rotary do you recommend #1
RussMan
Jefferson City, MO (central)
B3030 w/ FEL and 72" midmt
OK I need your input fellas. I have a Kubota 30 hp (B3030) with a MMM that does great. But at times I need to mow some pasture fields. So I bought a 5' rotary from TSC. It does OK, but feels a bit "big" for my little tractor. Not so much the PTO power that is the problem, but more it is sort of long and so when I go in terrain dips it gets pinched, and also it is fairly heavy causing my front end to be a bit light without the FEL on the tractor for weight.
So I am considering selling the rotary, and getting maybe a woods type finish mower (3PH) that I could mow in the raised position for tall grass, or perhaps a 4' rotary.
Thoughts? What is the best setup for my tractor and my needs on this. The MMM works great for cutting any grass up to about 12" tall but for the tall stuff I need something where I can cut it at a leaving grass at about 6-8" tall.
Can I mow in the raised position with a rear mount mower? Thoughts?
   / what mower/rotary do you recommend #2
I have a NH 3230 (32hp, 4.5klbs +liquid in tires, no FEL) and use a 6' RFM and a 5' rotary. I normally use the RFM, but if the grass gets too tall/thick, I hook up the rotary so I don't smoke the RFM belts. When I lift my RFM, the front lifts about 8" higher than the rear. I just can't see mowing with an RFM with the gauge wheels lifted off the ground working acceptably. Plus, you'd still have a problem with terrain as the dips would cause the RFM to change altitude (if it did work).
I'd focus on getting your rotary to work better for you. Right tool and all that... :)
Keith
   / what mower/rotary do you recommend #3
It's not really unusual for the front to need ballast when using a rotary cutter.
I use a 4' Land Pride cutter on my BX2660 and really think your B3030 should be able to handle a 5' cutter.
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2020 FREIGHTLINER M2 26FT BOX TRUCK (A52141)
2020 FREIGHTLINER...
Factory Cat Magnum Industrial Floor Cleaner (A50121)
Factory Cat Magnum...
