what model's to consider?
/ what model's to consider? #1
Carl Bill
Bronze Member
Claremore, Oklahoma
Kubota BX1500; Kubota L2800HST
I have a 2003 Kubota BX1500D. 48" MMM, FEL and box blade. This little beast has done everything I have needed it to do until now. I have a bit of dirt work to do along a dry stream bed on my 3 acres. The BX1500 just can't seem to move much dirt. It mows like a champ and moves dirt in the FEL just fine, but pushing dirt with the box blade is too much for it to handle.
I would like to move up to an L3400HST, but a B7800 may be more in my budget.
However, Mahindra and Kioti appear to have a possible cost advantage. (not to mention similar colors!)
Does anyone know what Mahindra or Kioti models would be in alignment with the Kubota's I mentioned? Any other thoughts on other brands with similar size/power?
The NH T1520 had been advertised somewhere as a possible model to consider, but I am not sure that would be at a cost advantage.
Any suggestions and/or comments are appreciated.
Thanks!
Carl
/ what model's to consider? #2
The Mahindra 2816 HST and 3316 HST would be the closest comparisons. Take a good in person look and test drive on these models. You will find them very easy to use and comfortable. Also they are Mitsubishi made in Japan, so quality and workmanshop is top of the line. Good luck with your shopping.
/ what model's to consider? #3
You should also take a look at loader and 3point lift capacities, and also the weight of the machine itself. When you check those out, the Mahindra will look better and better. I love mine, and would buy another in a heartbeat. I use mine for some mowing, but mostly loader and hoe work.
/ what model's to consider? #4
TYM has some great deals. Great Tractors too. I don't know if there is a dealer nearby. You can click on the link on this website put your zipcode in and find out.
/ what model's to consider? #5
You may want to throw the L2800 into the mix as well. The 2800 and 3400 are heavier than both the Mahindra's mentioned. The Mahindra 3316 will have a slight edge in lifting capacities and the 2816 will be about the same as both Kubota models. The 2800/3400 were a little more robust in the front end too. The 7800 is kind of in a class by itself because not many other models compare well in size and weight. The smaller Mahindras are heavier machines than the small Kubotas, but they lack a 3 range HST. You just need to drive them all and pick the best one for you. I don't think you can go wrong with a Mahindra of Kubota. I'd like to have a few of each.
Here is the first quote I have gotten on the Kubotas. No reply so far from a Mahindra dealer.
Kubota B7800 HST Tractor w/ R4 tires
Kubota LA402-1 Loader $15,500.00
Kubota L3400 HST-1F Tractor w/ R4 Tires
Kubota LA463-1 Loader
Skid Steer Attachment $18,900.00
Do these prices look like they are decent? :confused:
I am thinking that for the additional $3,400, the L3400 may be worth the cost.
/ what model's to consider? #7
The 7800 price looks ok. The price of the 3400 seems high to me. When I priced them 2 years ago in was in the 16,500 - 17000 range.
According the the salesman, the new 3400's are improved and have a bit more power. I also had him quote the more expensive FEL with skidsteer attachment. He said that the MSRp on the new one's had gone up and to be sure when I compared to look to see that I was getting quotes on current models... or he knew he would be high as compared to last years model.
I would still like to hear from a Mahindra dealer. See what they had to offer in comparision.
/ what model's to consider? #9
Are you trading? The Kubota dealer will probably allow you more for your orange machine than the Mahindra dealer -- it should be easier for him to resell it.
When I was looking, the Mahindra dealer offered me $3k for my little B7100 while the Case/Kubota dealer I bought from (Case Dx29 on A-plan) allowed me $4.5k
/ what model's to consider? #10
There is a good price difference between the pre-emmissions L3400 and the L3400 "XtraPower" version, none the less... the price is great for the B7800 and a tad high for the L3400. The lift capacity difference there is only about 150lbs, unless you what the big frame I'd probably spring for the B7800.
Not trading the BX1500. It will still be used to mow and for smaller FEL work.
If the B7800 is only 150 lbs less capacity (FEL) than the L3400, then I may be looking closer at the smaller tractor. A larger, heaver tractor may be better for pushing dirt, but I would think either one of these would be much better than the little BX1500.
/ what model's to consider? #12
I bought a 2008 Kioti DK40se 4X4(41.5 hp gear)with a FEL & loaded rim guard R-4 tires this past spring with the Kioti $1000 cash rebate this past spring for $18,000 out the door price.coobie
/ what model's to consider? #13
Take a look at the Montana's. I got a 3644 which is 38.5 HP shuttle with a loader tooth bar and filled tires for 15,000. It also include dual remote hydrualics in the rear and a real open platform. 4 cylinder Mitsubishi motor, very smooth. When I compared to Kubota and Mahidra, there was no comparison for the money and quality and features. Take a look you will like what you see.
Does Montana have HST? Price is nice, but for the FEL work, I really want HST. My BX1500 has HST (or it's versions of HST) and I have become so accustomed to using the FEL with it, that I do not want to have to relearn to use gears. I think for a tractor that will primarilly be used for FEL work, HST is a requirement.
Now if I were only using it fo rmowing... different story.
/ what model's to consider? #15
With the free FEL deal Kioti is offering on the CK35 you should be able to get an HST model for very close to the price you were quoted on the B7800.
/ what model's to consider? #16
The Montana's do have a HST also in all models in the r series 28 , 38.5, or 43 HP. The Hst are about $800 higher. They offer a lot of tractor for the money. The Kioti ck 35 is also a very good deal, although they don't have quite as many features and have 3 cylinder Daedong verse the 4 cylinder Mitsibushi. The mitsibishi is smoother.
Just got a quote on a Montana R series, 2840HST w/FEL. $19,500.00 With $1,000 factory rebate and another $750 if I came up with my own financing.
So $17,750 for a 28 HP 2840HST Montana, 4X4, W/FEL.
I think $15,900 for the 30 HP L2800HST Kubota 4X4, w/FEL is sounding much better all the time.
Never heard from the local Mahindra dealer. Have not looked at Kioti yet.
/ what model's to consider? #18
Don't make a move until you've checked out Kioti: CK25, CK27, CK30, CK35 and DK35. Free loader on the CK35 right now. You want a ground engagement machine. Kioti is the best of the lot. Heaviest except for Branson (also a good choice).
/ what model's to consider? #19
Whatever tractors you are considering, go to the dealer, sit on them, try them out, and decide which tractor fits you the best and is most natural for you to operate. And while you are about it, evaluate the dealer to see which you are most comfortable with. The dealer is probably as important to your decision as the tractor.
Happy shopping!
/ what model's to consider? #20
Good luck on whatver tractor you get.
one thing though.. i see you mentioned pushing dirt... keep in mind that box blades pull dirt great.. but you have to be carefull pushing dirt... a scut / cut and a rear blade is not a bull dozer. Those drag links are great in tension.. not so great under compression.. looking at the geometry.. etc..
soundguy
Thanks!
Carl
UNUSED RAYTREE REDM32 - 32" EXCAVATOR DRUM MULCHER (A62131)
UNUSED RAYTREE...
2002 Freightliner FS65 Chassis Bus, VIN # 4UZAAXAK52CJ75416 (A61165)
2002 Freightliner...
Red Cedar Glider Chair (A61569)
Red Cedar Glider...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
(INOP) YANMAR VIO35-5 UNIVERSAL EXCAVATOR (A62129)
(INOP) YANMAR...
2022 KOMATSU PC130-7 EXCAVATOR (A62129)
2022 KOMATSU...
