What Luck on my 372
   / What Luck on my 372 #1
wushaw
Elite Member
Bristol Texas
Kubota L2800, 15 hp 372 Mitsubishi
I noticed the other night the idiot light for the charging system was on dim, it was dark out so that's how I could see it otherwise you couldn't tell during the daylight hrs.... and I thought ok it has to be one of two things...regulator or alternator so I hooked up a volt meter to it and it was putting out 16v so it has to be a regulator.
I was then in the process of thinking how I was gonna be putting in a AC delco alternator since I wasn't even gonna try to locate a regulator for this and the cost would surely be more than an AC Delco unit.
Last night I went to look at what I was gonna have to do and I noticed a broke wire on the plug (used to be a plug) on the back of the alternator so 2 min later and a new connector she was charging 14.2v:)
   / What Luck on my 372 #2
I hope my plug never breaks on the alt. It is dry and cracking now.
Glad you caught it!
Bill
It will look like there never was a plug before long. The connections are just spade connectors.
My 372 is parked under cover also so sun and direct rain doesn't get on her.
   / What Luck on my 372 #4
I know it. I keep mine in the garage since I have owned it and when I get the woodshed finished it will have a parking place out there.
Bill
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2003 Land Rover Discovery 4WD SUV (A59231)
2003 Land Rover...
PENDING SELLER CONFIRMATIONS (A59904)
PENDING SELLER...
2016 Deere 180G (A60462)
2016 Deere 180G...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
16ft T/A Utility Trailer (A59231)
16ft T/A Utility...
