What lubricant in caps on spool valve
   / What lubricant in caps on spool valve #1
BeezFun
IL
Kubota B2710
The caps on my front loader valves were filled with rust and water, I cleaned them up and drilled a drain hole. What kind of lubricant should I put on the end of the spool that extends into the cap before I reassemble things? There was a light grease on there when I took it apart, not as heavy as regular grease that I use on the fittings.
   / What lubricant in caps on spool valve #2
Any grease you have around is fine, no need to get fancy here. You want a medium/heavy grease though or it will run out of your drain hole when it gets hot.
tnx, didn't think about it being too lightweight and running out.
I rediscovered that my bucket has a float for the dump position. I never used that much and forgot all about it because there was so much water, ice and crap in the cap that I don't think the spool could extend far enough to go into the float position. Another good reason to put a drain hole in that cap.
   / What lubricant in caps on spool valve #5
Great Beez, this was a huge issue in many older Kubota's
UNUSED AGT KRW23 WHEEL LOADER (A51247)
UNUSED AGT KRW23...
2000 HONDA FOURTRAX 300 ATV (A51247)
2000 HONDA...
UNUSED HURRICANE G350 PORTABLE CEMENT MIXER (A51248)
UNUSED HURRICANE...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
INOP/NON-RUNNING Chevrolet Rollback (A51573)
INOP/NON-RUNNING...
