What lubricant in caps on spool valve
   / What lubricant in caps on spool valve #1
BeezFun
IL
Kubota B2710
The caps on my front loader valves were filled with rust and water, I cleaned them up and drilled a drain hole. What kind of lubricant should I put on the end of the spool that extends into the cap before I reassemble things? There was a light grease on there when I took it apart, not as heavy as regular grease that I use on the fittings.
   / What lubricant in caps on spool valve #2
Any grease you have around is fine, no need to get fancy here. You want a medium/heavy grease though or it will run out of your drain hole when it gets hot.
tnx, didn't think about it being too lightweight and running out.
I rediscovered that my bucket has a float for the dump position. I never used that much and forgot all about it because there was so much water, ice and crap in the cap that I don't think the spool could extend far enough to go into the float position. Another good reason to put a drain hole in that cap.
   / What lubricant in caps on spool valve #5
Great Beez, this was a huge issue in many older Kubota's
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
JD 1814E LOT IDENTIFIER 264 (A53084)
JD 1814E LOT...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
