What lubricant in caps on spool valve
   / What lubricant in caps on spool valve #1
BeezFun
Veteran Member
IL
Kubota B2710
The caps on my front loader valves were filled with rust and water, I cleaned them up and drilled a drain hole. What kind of lubricant should I put on the end of the spool that extends into the cap before I reassemble things? There was a light grease on there when I took it apart, not as heavy as regular grease that I use on the fittings.
   / What lubricant in caps on spool valve #2
Any grease you have around is fine, no need to get fancy here. You want a medium/heavy grease though or it will run out of your drain hole when it gets hot.
tnx, didn't think about it being too lightweight and running out.
I rediscovered that my bucket has a float for the dump position. I never used that much and forgot all about it because there was so much water, ice and crap in the cap that I don't think the spool could extend far enough to go into the float position. Another good reason to put a drain hole in that cap.
   / What lubricant in caps on spool valve #5
Great Beez, this was a huge issue in many older Kubota's
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A53472)
Koyker Loader...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
UNUSED FUTURE D-PDQ 45" LAND LEVELER (A51248)
UNUSED FUTURE...
2014 Caterpillar 289D High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
