Loader What loader should I consider for a 4x4 Cab equipped John Deere 2355
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #1
sbeckwith
John Deere 4720, Kubota L3830, John Deere 2355 MFWD, John Deere 4430, Case 1030, John Deere B, John Deere 730D, Hustler SD60
Looking for advice on which loader I should consider adding to a John Deere 2355 MFWD Cab tractor. Loader will be used for light bucket chores, handling round bales with bale spear, and move 4x4 hay-ledge with a bale squeeze. I'd like to know which loaders would work as well as which loader works best.
Thanks in advance for sharing your knowledge!
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #2
The 2355 I had had a John Deere 175 loader.
It was stout, pin on bucket though.
I'd prefer a quick attach set-up, but all options are on the table
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #4
JD loader model 240 or 245 or 620. You could also investigate Koyker that now builds loaders from JD spec's.
I found a 146 Loader with cables used to run to a Joystick control inside the cab. It was pulled off of a 2555 2wd open station John Deere. Will this mount up to the 2355 MFWD Cab tractor? Unit is in pretty good shape.
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #6
For MFWD you want the 640 not the 620.
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #7
I saw no footnotes in the 146 loader parts catalog singling out a MFWD tractor so I'm going to state it will fit a MFWD.
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
40ft Sea Container (A52384)
40ft Sea Container...
FUEL  TANK (A55745)
FUEL TANK (A55745)
Hercules Gun Safe (A55853)
Hercules Gun Safe...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2007 FREIGHTLINER 120 CLASSIC (INOPERABLE) (A55745)
2007 FREIGHTLINER...
