Loader What loader should I consider for a 4x4 Cab equipped John Deere 2355
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #1
sbeckwith
Member
John Deere 4720, Kubota L3830, John Deere 2355 MFWD, John Deere 4430, Case 1030, John Deere B, John Deere 730D, Hustler SD60
Looking for advice on which loader I should consider adding to a John Deere 2355 MFWD Cab tractor. Loader will be used for light bucket chores, handling round bales with bale spear, and move 4x4 hay-ledge with a bale squeeze. I'd like to know which loaders would work as well as which loader works best.
Thanks in advance for sharing your knowledge!
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #2
The 2355 I had had a John Deere 175 loader.
It was stout, pin on bucket though.
I'd prefer a quick attach set-up, but all options are on the table
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #4
JD loader model 240 or 245 or 620. You could also investigate Koyker that now builds loaders from JD spec's.
I found a 146 Loader with cables used to run to a Joystick control inside the cab. It was pulled off of a 2555 2wd open station John Deere. Will this mount up to the 2355 MFWD Cab tractor? Unit is in pretty good shape.
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #6
For MFWD you want the 640 not the 620.
   / What loader should I consider for a 4x4 Cab equipped John Deere 2355 #7
I saw no footnotes in the 146 loader parts catalog singling out a MFWD tractor so I'm going to state it will fit a MFWD.
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
10 ft Shipping Container (A55973)
10 ft Shipping...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A56138)
2014 INTERNATIONAL...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A56138)
2016 INTERNATIONAL...
2022 Case IH 8250 Axial-Flow Combine (A53485)
2022 Case IH 8250...
