What kind of shackles to use to hold chains on?
   / What kind of shackles to use to hold chains on? #11
You can get a tool that holds the link and has a bar that sets against the pin and then you drive the pin out or rather back.
A punch will work but not as well.
   / What kind of shackles to use to hold chains on? #12
I used chains on a car back in the 60's, on a 2WD pickup in the early 70's and on my first small 2WD tractor (Cub 154 LoBoy). In my limited experience with chains, I used quick links for fixing the side chains:
3/16" Zinc Plated Quick Link
For connecting the cross chains, these are available:
Medium Truck Cross Chain Hook - 2312
On the tractor I used springs as in the link below. I used two springs on each wheel and had extra S-hooks so each spring could catch the side chain at 3 places. The chains weren't tight on the tires but the tractor didn't go fast enough to cause any problems.
CENTURY SPRING CORP - Zinc Plated Screen Door Spring 3/8" OD x 16-3/8" Long #TV183;)
   / What kind of shackles to use to hold chains on? #13
I have been using the slide chain fasteners that came with the chains. They have been rubbed up against many trees and rocks. Never lost a chain off the tire to date.
I also never used springs. Just throw them on. Drive around a bit then re tighten.
2003 Ford F-550 Dump Truck, VIN # 1FDAF57P83ED09110 (A57453)
2003 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CAT D8 (A58214)
CAT D8 (A58214)
UNUSED CFG INDUSTRIAL MH12R EXCAVATOR (A58375)
UNUSED CFG...
2021 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
