What kind of shackles to use to hold chains on?
   / What kind of shackles to use to hold chains on? #11
You can get a tool that holds the link and has a bar that sets against the pin and then you drive the pin out or rather back.
A punch will work but not as well.
   / What kind of shackles to use to hold chains on? #12
I used chains on a car back in the 60's, on a 2WD pickup in the early 70's and on my first small 2WD tractor (Cub 154 LoBoy). In my limited experience with chains, I used quick links for fixing the side chains:
3/16" Zinc Plated Quick Link
For connecting the cross chains, these are available:
Medium Truck Cross Chain Hook - 2312
On the tractor I used springs as in the link below. I used two springs on each wheel and had extra S-hooks so each spring could catch the side chain at 3 places. The chains weren't tight on the tires but the tractor didn't go fast enough to cause any problems.
CENTURY SPRING CORP - Zinc Plated Screen Door Spring 3/8" OD x 16-3/8" Long #TV183;)
   / What kind of shackles to use to hold chains on? #13
I have been using the slide chain fasteners that came with the chains. They have been rubbed up against many trees and rocks. Never lost a chain off the tire to date.
I also never used springs. Just throw them on. Drive around a bit then re tighten.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A57453)
2003 Isuzu NPR-HD...
UNUSED AGT INDUSTRIAL 40 GALLON AIR COMPRESSOR (A58376)
UNUSED AGT...
7021 (A55851)
7021 (A55851)
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
