What kind of oil for a PHD
   / What kind of oil for a PHD #1
Bellville
Katy, Texas
JD 790
I checked the level of oil in the gearbox on my post hole digger last weekend and noticed it was little low, (nothing serious), but it made me realize that I don't know what type of oil it uses.
I suspect it would be a gear oil similar to what is used in a truck rear end, but must admit I don't really know. Can someone tell me what it is, type and viscosity?
Thanks
   / What kind of oil for a PHD #2
You're right, Jack, gear oil. I don't know what specific weight yours recommends, but would guess a 90W, however, in view of the normal temperatures in your area, I wouldn't hesitate to use the 85W-140 myself. Purely personal opinion, of course.
   / What kind of oil for a PHD #3
I think Bird is right on the money. Unless your documentation shows anything different like short fiber grease.. or pourable grease.. go with a gear oil.
Even outboard 85/140... If it is low.. do you see any leaks.. or has it been a real gradual loss.
Soundguy
Thanks Bird, I figured as much but it is always nice to have a little reassurance /forums/images/graemlins/smile.gif
Soundguy, thanks for your input, I have not noticed a leak, I just checked it and it was alittle low. Must be a really gradual loss.
   / What kind of oil for a PHD #6
At the risk of sounding like a 'know-it-all' (which I certainly am not!) keep in mind that your PHD gear box is probably not intended to be full of lube or even close to full. Most gear boxes should be about 1/2 full to prevent blowing out the seal. There was this friend of mine who made that very mistake. /forums/images/graemlins/confused.gif
2013 Bobcat T180 (A47477)
2013 Bobcat T180...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A54313)
2012 INTERNATIONAL...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
