What kind of jig saw blade to use to cut plexiglass or another cutting method
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #1
johneic
Paducah (West) Kentucky
JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
I need to cut some plexiglass, I do not know of a plexiglass cutting forum and am on here a lot so asking here.
In my past experience too fast a blade speed will melt the plexi so I plan to use my variable speed jig saw, would a fine or coarse tooth clade be better? I am thinking fine.
or should I score it like they do at the hardware store? I do not have a fancy machine like them but I guess I could use a metal straight edge and a razor knife and score it 10-20 times?
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #2
I just use a jigsaw with a metal blade I cut fast no melting just a lot of the dust stays on the edge nock off with a straight edge.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #3
I use a finish cut wood blade (very little tooth offset) and a slow speed.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #4
I just cut some last week with what ever blade was in the table saw. It was maybe a 24 tooth carbide blade 10" and fed it slow. With a jig saw, I'd put down some removable masking tape on the material if it does not still have the protective sheet, it will scratch & mar very easy with all the shaking & vibration from a jig saw.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #5
Use a fine tooth blade for hard woods or metal, also putting a strip of 2" masking tape over the cut will let you draw a cut line, prevent edge chipping, and shoe scuffing from the saw.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #6
I also use a grinder with a cut off wheel.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #7
I use a fine metal blade in my circular saw installed in reverse, it also works well on metal roofing..
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #8
I cut plexi-glass and other plastics such as styrene light lenses this way. If final size is very important, cut it oversize and trim later or use a router.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #9
Put a strip of masking tape where you wish to cut and you can use a table saw with a zero clearance insert or if a jig saw keep the speed slow enough to avoid melting.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #10
I use my table saw with a blade for plywood on it and feed slowly.
1265 (A50490)
1265 (A50490)
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
TRAIL MASTER...
2021 Doyle 8 Ton Trailer Tender (A51039)
2021 Doyle 8 Ton...
Komatsu PC138 (A50490)
