Box Scraper What kind of box blade is this thing?!?
   / What kind of box blade is this thing?!? #1
bottlediger
york, pa
none
I bought this the other day and it seems different than any other Hydraulic box blade Ive seen on the Internet. Seller bought it for resale so didnt have much detail. Said it was an old Gannon brand. I bought it because it looks real heavy duty and I also needed something 1000lbs plus for rear ballast.
My questions are have you ever seen hydraulic rippers mounted like this? Ill have to change out the lines before I can test it out.
Also the rear blade floats but doesnt seem to lock down ? Would it be a good idea just to weld it shut ?
Let me know your thoughts on this thing.
Can someone help me out on loading pictures. Can稚 figure it out
   / What kind of box blade is this thing?!? #4
Sure looks like a Gannon , my second guess would be a Rhino .......................
Welcome to TBN BTW ! .................................:thumbsup:
   / What kind of box blade is this thing?!? #5
Try youtube for more info you may have diamond in the ruff.
   / What kind of box blade is this thing?!? #6
Also the rear blade floats but doesn't seem to lock down ? Would it be a good idea just to weld it shut ?
If you get it on a flat hard surface, you will probably notice the rear blade sits lower than the front blade. That allows you to use the rear blade as a cutting surface without interference from the front blade, allowing it to cut deeper. Leave it alone.
Do you guys see how the lower links connect to the hydraulic scarifiers mount and not a fix bar mount. Dont you think thats weird? I cant visualize how it will move with the links attached without actually hooking it up.
   / What kind of box blade is this thing?!? #8
Looks like you have stumbled into a really fine implement. I would not modify anything until it has been positively identified and you have an Op Manual for it. Yes - the scarifier setup is unusual. This could well be one of its better features. Floating rear blade in not unusual.
I would love to ID it and look up the manual it has no markings anywhere I can see
   / What kind of box blade is this thing?!? #10
Keep the faith. It's likely somebody on TBN will recognize the unit.
2025 Swict 84in Bucket Skid Steer Attachment (A55851)
2025 Swict 84in...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
2021 Kubota SVL75-2 Track Loader (A55314)
2021 Kubota...
2005 Kaufman Trailers Car Hauler Trailer (A53421)
2005 Kaufman...
More info coming soon! (A55851)
More info coming...
