What is this???
/ What is this??? #1
wksinatl
Atlanta
case IH 485
I found this in my Dad's barn. Any idea what is is/used for?
thanks,
Keith
/ What is this???
another angle...
Keith
/ What is this??? #4
I'm with Highbeam.
Mine still have the pulley...
/ What is this??? #5
I think there was a double shiv on the shaft and the little frame in front was to guide the rope. See if there is another one in the barn. The mate might be a single or a double. /forums/images/graemlins/wink.gif
/ What is this???
thanks guys!
Keith
/ What is this??? #7
It looks a bit strange to be part of a block. The short U shaped piece pivoted on the end may provide a clue. Has it been bent or does the shape look original. Any holes in it other than the pivot ends? If there are holes, are any of them threaded?
/ What is this??? #8
In the past, horses (and tractors) were used instead of elevators to raise hay to the top of the barn. There was a track running in the peak of the barn to the outside. A stack of 6-8 bales of hay were picked up with large thongs and traveled up the side of the barn to the upper rail. When the hay reached the top, it would release and allow the hay to travel horizontally to where you wanted to stack the hay. There was a release rope to turn the thongs loose, dropping the load. To me, that looks like the clevis and pulley (missing) that traveled along the top rail. I'm 53 and I've only seen these used twice in my life. Most barns had this system in them though.
/ What is this??? #9
An old rope type snatch block - (probably for a well?) with the sheave missing. Find the sheave and it may be useful.
/ What is this??? #10
</font><font color="blue" class="small">( In the past, horses (and tractors) were used instead of elevators to raise hay to the top of the barn. There was a track running in the peak of the barn to the outside. A stack of 6-8 bales of hay were picked up with large thongs and traveled up the side of the barn to the upper rail. When the hay reached the top, it would release and allow the hay to travel horizontally to where you wanted to stack the hay. There was a release rope to turn the thongs loose, dropping the load. To me, that looks like the clevis and pulley (missing) that traveled along the top rail. I'm 53 and I've only seen these used twice in my life. Most barns had this system in them though. )</font>
I'm 65 and only witnessed that once, Bill, probably because ours did one bail at a time and was man powered. I'll take a look the next time I get up north to where the barn is, I'll have to use binoculars though, I ain't climbin' ut there. /forums/images/graemlins/shocked.gif
/ What is this???
OK, after checking with another family member I was told that it was used to get hay to the top of the barn and the pulley is indeed missing. Mystery solved!
thanks guys,
Keith
/ What is this??? #12
Back when my Grandfather put hay in the barn he did not use elevators or hooks, he used us kids and pitchforks /forums/images/graemlins/wink.gif
/ What is this??? #13
I got one of them with a steel sheave hanging in my garage right now. It just hangs there cause it reminds me of days gone by.
/ What is this??? #14
</font><font color="blue" class="small">( I found this in my Dad's barn. Any idea what is is/used for?
thanks,
Keith )</font>
Arrgggghh.....wher'd ya find that matey? I'll ge ya a ruby necklace and a pint o me rum if'n ya gime my hook back.
Dave
/ What is this??? #15
I'm 39 and remember helping my grandpa put up loose marsh hay with a hayloader and hay forks. I was 7 or 8 and tried to keep up with the hayloader but could not stack the hay to the front of the wagon fast enough. After the wagon was heaped full it was backed up the barn hill and the wagon was unhooked. Then a rope was attached to the tractor and you drove back down the barn hill to lift the hay, then you backed up the tractor and hooked up to another rope to move the hay to the selected part of the mow, then you yanked on a trip rope to drop the hay, then you pitched the hay off to the front or back of the mow. Round bales are sure easier but not as much fun for a 7 year old boy.
FORD F-250 (INOPERABLE) (A60736)
FORD F-250...
1995 Kawasaki Bayou 300 4x2 ATV (A60352)
1995 Kawasaki...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2021 KENWORTH T680...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
