What is this tool used for?
   / What is this tool used for? #1
DocHeb
Michigan
New Holland TC40D Supersteer
I found this in my yard. It has a nail point at the top apex that might function as a compass point or stabilizer point, and two retractable blades on the side. What is it used for?
   / What is this tool used for? #2
I saw something like that advertized on TV once. It's not a tool, it's a shelf. You stick it in a corner and slide the lever underneath the shelf to force the sharp pins into the wall to support the shelf.
   / What is this tool used for? #3
It is hard to read much of the text on the item...you might try "Googling"
I tried searching for "scientific products M1075" (all I could read from the picture) no joy...
   / What is this tool used for? #4
Uhmm... Unless I am mistaken, the Scientific Products M1075 is just the ruler that was put in the photograph to show the scale.
I'm gonna go with "shelf" here as well.
S1
OK I see that now...what is the item made of? it looks like a soft (paper) material...unless it is firmer how could it be used as a shelf?
I think you're right - I googled "instant shelf" and it there are products for sale that look the same. The nailpoint at the end goes into the corner, and the two small blades extend into the drywall a bit to hold it horizontal. I wouldn't use it to hold anything of value, however - it seems like it has a pretty tenous hold on the drywall.
Thanks all.
   / What is this tool used for? #6
It is either a quick shelf or the bottom side of a thermal panel from an alien space craft. :p
   / What is this tool used for? #8
yup - its a shelf to fit in corner. I have it in the corner of my garage.
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
2012 Ram 3500 Crew Cab Flat Bed Truck (A55788)
2012 Ram 3500 Crew...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
