What is this hole on the transmission for? (JD 5085E)
   / What is this hole on the transmission for? (JD 5085E) #11
Didn't realize it wasn't a blind hole, my bad. I looked at mine and thought it was a blind hole, just drilled longer then the rest. I will have a closer look to be sure. It may be as Soundguy says, a hole in the bellhousing to let a mainseal leak drip out. I have never seen a hole this big for that purpose however. Usually just a small slit or hole to let oil out and not let debris in.
   / What is this hole on the transmission for? (JD 5085E) #12
It's a Common practice to put a weep hole in the bellhousing...
I've ran the tractor 3 times since I posted the OP, since my dealer won't be open until tomorrow.
The first time, I ran it about 30 minutes. No leaking.
The second time was about 1 hour, there was some dripping afterwards.
Ran today for about 2 hours, no dripping.
   / What is this hole on the transmission for? (JD 5085E) #14
Trans input shaft seal bad, or vent on trans not working and putting undue pressure in case.
Been looking on JD parts. I suppose it could be the oil pump seal that's bad. My dealer is backed up with service calls so they won't be able to come out until late this week or next week.
   / What is this hole on the transmission for? (JD 5085E) #16
Maybe your service guy can take a look in that hole with something like an endoscope camera and see what is happening.
   / What is this hole on the transmission for? (JD 5085E) #17
easier to just see if it is hydro oil or engine oil. ;)
   / What is this hole on the transmission for? (JD 5085E) #18
I have the same threaded hole on my 5093E..I have no idea why there would be a threaded hole there but I'd sure like to know..
   / What is this hole on the transmission for? (JD 5085E) #19
Is it possible that your hydraulic system is overfilled and this is a vent or something and it is purging the over flow out of this hole?
Check your site windows in the back by the pto shaft and see how much oil is in there. With all hydraulics in the down position, you should see fluid line half way up on the upper site glass. If there is oil all the way to the top, then you might be overfilled from the factory. Not likely, but possible.
Not overfilled. Fluid is to the top of the lower sight glass, none in the top sight glass.
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
154 (A52708)
154 (A52708)
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
1999 International 8000 Semi Truck (A59814)
1999 International...
