What is the time frame to edit a thread title? 30 minutes?
   / What is the time frame to edit a thread title? 30 minutes? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
If I start a thread what is the time period I can edit a title?
It always seemed shorter than to edit a post.
And what is the time frame before it shows a post has been edited?
It seems I've 15 minutes before it reflects the post has been edited.
   / What is the time frame to edit a thread title? 30 minutes? #2
Re: What is the time frame to edit a thread title? 5 minutes?
I just did a title edit using the Advanced option. (palm to forehead)
Might have been a couple of minutes after the original send. No clue as to the Max time...
Yup, I've been playing around with this, up to 12 minutes, so far.
But I just noticed the title in the reply stopped updating after 5 minutes.
Is that affected by the first reply by CalG?
   / What is the time frame to edit a thread title? 30 minutes? #5
You can also delete posts and threads but I haven't figured the time limit on it.
   / What is the time frame to edit a thread title? 30 minutes? #6
You can get your thread title changed by the admin, or move the thread to the most viable forum, etc.
   / What is the time frame to edit a thread title? 30 minutes? #7
IIRC, its 24 hours to edit a post and 7-10 minutes to not have it show that you edited it.
Aaron Z
Aaron Z
Thanks, and as for "editing typos in the title" which was the stimulus for this thread, is here a time limit or is it until there is a response?
   / What is the time frame to edit a thread title? 30 minutes? #9
I am not sure, I would suspect that it is 24 hours, but I could be wrong (and it doesn't always change the titles on the responses even if you do it right after you post).
Aaron Z
   / What is the time frame to edit a thread title? 30 minutes? #10
I'm trying to think of why someone would not want someone to know that they've edited their post. Probably obvious but what am I missing?
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
