What is the time frame to edit a thread title? 30 minutes?
   / What is the time frame to edit a thread title? 30 minutes? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
If I start a thread what is the time period I can edit a title?
It always seemed shorter than to edit a post.
And what is the time frame before it shows a post has been edited?
It seems I've 15 minutes before it reflects the post has been edited.
   / What is the time frame to edit a thread title? 30 minutes? #2
Re: What is the time frame to edit a thread title? 5 minutes?
I just did a title edit using the Advanced option. (palm to forehead)
Might have been a couple of minutes after the original send. No clue as to the Max time...
Yup, I've been playing around with this, up to 12 minutes, so far.
But I just noticed the title in the reply stopped updating after 5 minutes.
Is that affected by the first reply by CalG?
   / What is the time frame to edit a thread title? 30 minutes? #5
You can also delete posts and threads but I haven't figured the time limit on it.
   / What is the time frame to edit a thread title? 30 minutes? #6
You can get your thread title changed by the admin, or move the thread to the most viable forum, etc.
   / What is the time frame to edit a thread title? 30 minutes? #7
IIRC, its 24 hours to edit a post and 7-10 minutes to not have it show that you edited it.
Aaron Z
Aaron Z
Thanks, and as for "editing typos in the title" which was the stimulus for this thread, is here a time limit or is it until there is a response?
   / What is the time frame to edit a thread title? 30 minutes? #9
I am not sure, I would suspect that it is 24 hours, but I could be wrong (and it doesn't always change the titles on the responses even if you do it right after you post).
Aaron Z
   / What is the time frame to edit a thread title? 30 minutes? #10
I'm trying to think of why someone would not want someone to know that they've edited their post. Probably obvious but what am I missing?
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2002 Miller Trailblazer 301G Towable Welder Generator (A55851)
2002 Miller...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
