What is the normal RPM's of the newer 4 cylinder diesels?
   / What is the normal RPM's of the newer 4 cylinder diesels? #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
I have an 09 B3200. When the throttle is set to the lowest position, RPM's are at 1000. Is this normal? Seems a little high to me..........
   / What is the normal RPM's of the newer 4 cylinder diesels? #2
That's what my 4 cylinder kioti engine runs at idling
   / What is the normal RPM's of the newer 4 cylinder diesels? #3
My B3030HSDC has basically the same engine and idles at 1025 fully warmed up-sounds normal to me.
Thanks guys appreciate the responses.
   / What is the normal RPM's of the newer 4 cylinder diesels? #5
   / What is the normal RPM's of the newer 4 cylinder diesels? #6
Think some of the idle speeds are being upped to produce more heat in the engine so they will meet the new tier 3 levels.
David Kb7uns
2018 Izuzu NPR (A50120)
2018 Izuzu NPR...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2023 Kubota L2501D 25HP 4WD Front Loader Utility Tractor (A50322)
2023 Kubota L2501D...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
John Deere 825I Gator (RUNS) (A50774)
John Deere 825I...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
