What is the major difference?
/ What is the major difference? #1
GreatWhitehunter
Veteran Member
Eastern CT
JD 110 TLB
What are the differences between Midmount mowers and 3pt mower other that attachment methods? I'm looking at purchasing some land. Three acres are grass. I plan on getting horses so I'll be making an acre or so a paddok for them. I plan on mowing the rest. I like the look of a well kept lawn so the quality of the cut matters. I have JD 3320 w/o the mid pto. I really don't like the idea of the mid mower anyways since it will get in the way while clearing land and digging. I will probalbly mow weekly so I think the 3pt mower will be best of both worlds. I was also wondering about rotary cutters. What are the major difference in these implements. If I buy it will be the JD brand (frontier) most likley. Any experiance with this subject would be great. I know nothing about these implements so please explain in clear detail.
Matt T.:D
/ What is the major difference? #2
Matt if you don't have a bunch of obstacles to mow around go with the rear finish mower. It mows as well as the MM but is so much easier tho take off and put on. A rotary mower is a brush hog . Great for brush and weeds not for yard. I prefer the rear discharge.
Bill
/ What is the major difference? #3
I'm not a big fan of mid-mount mowers either. They're model specific and too darned expensive!
As far as quality of cut, I don't think you'd see much difference between the MMM and rear mower. You may have to do a bit more backing up and possibly a bit more trim work with the rear mower...but maybe not. You'll find out when you get the rear mower.
A rotary cutter is for field and brush work. They do not give a "lawn quality" cut. If you must clear a field, don't use a mower. The brush and field grasses will tear the mower up. Cutters are much more robust and can handle quite a bit of tough work.
That 3320 is a nice tractor! I looked into one about a year ago. I'm quite happy with my 790's power, but I wanted more transmission flexibility. I really liked that Power-Reverser (not a hydro fan here). However, more debt isn't in my plans at this time. I'm sure you enjoy your tractor!
/ What is the major difference? #4
GreatWhitehunter:
3PH mowers and cutters do not compromise the ground clearance of your tractor, are easier to attach and detach, and give you a greater variance with cutting heights. Jay
/ What is the major difference? #5
Matt T.:D
For 2 acres of grass I'd consider a ZTR mower. Lotsa choices. But be sure that the "grass" area is smooth like a landscaped lawn or the ZTR will really bounce around. You don't want to use a ZTR on pasture land which generally is pretty rough and uneven.
I have a 10-acre spread with about 7 acres of pasture land and a 21-hp Kubota B7510HST that's 4WD and has the LA302 FEL. I mow the pasture with a 4-ft wide King Kutter rotary mower. Takes me about 90 minutes per acre running in low range and going slow to avoid gopher holes, etc.
For my approximately 1 acre of grass around the house and in the almond orchard I use a cheap 42" Huskee riding mower from Tractor Supply Co.
My Bota has the forward PTO to handle a MMM, but they're pricey and a hassle to hook up and remove from the tractor. The KK mower is really easy to hook onto the 3 point hitch.
/ What is the major difference? #6
My Woods 72" 3 pt mower does a better looking job on grass than my Cub Cadet. I won't say that it cuts any better but it does a way better job of dispersing clippings and it's a side discharge, too.
/ What is the major difference? #7
Matt T.:D
we have a horse less than a year - plus some sheep for longer time - but I would think you will need all of those 3 acres to rotate pastures. With just little bit of rain horse will totally destroy the area he/she is in. If I had the option to move or buy land, I would give our animals at least 3 optional pastures 1 acre each. Same thing for dry summer, they will eat it down flat if theyh dotn have enough space.
I am sure here are people who now much better the me how much land you need for a horse.
That said, I would notbe really worried about mowing the rest:) - my $0.02 only.
/ What is the major difference? #8
Mid mount mowers...
-cut you clearence to 6"
-discharge all the grass thru a narrow chute and clump long grass clippings
-are a tremendous pain to take off/put on
-cost 2-3 times as much
Rear 3pt mowers
-Don't rob clearence
-rear discharge models spread clippings nicely
-easy on/ off
-left on, they act as a counterweight for loader work
BTW...I have a mid-mount for sale, would you believe?
/ What is the major difference? #9
I must be the only oddball on this preference. I have a 72" inch Mid mount/Rear Discharge for my DX33 and love it. With the rear discharge, I can mow right up to my trees, retaining wall, sidewaks etc on either side of the deck. With this and the hydro it makes mowing a breeze. No clumping problems, although the rear discharge is more of a mulcher than a discharge and can bog down in deep grass. As for removal, my mower only has the pto and 4 pins to remove. I can remove or attach the deck in about 5 minutes tops if doing heavier loader work. With all the trees I have and tight areas to get into the mid mount works great for my needs.
jk
/ What is the major difference? #10
I am voting for the RFM. For your tractor, I would recommend either the 60" or 72" Frontier brand. The RM series is made by Woods Equipment and is I match compatable. The rear discharge is the ticket also. My only complaint is that I have no grass; I explicitly bought my RFM to mow at my parents' places, one of which is around 2.5 acres and the other 10+, half of which I mow every other time. It can require a longer trailer to haul a RFM and if you choose to leave the loader on, it pushes 18' in length. I bought my dad a 757 JD ZTR to mow with and I like to use it, but not at their mountain place, too tippy. My tractor will mow almost as fast and does just as good a job, and better when the grass is heavier. I really would not look at a mid mount mower unless you have plans to leave it on or if you mow at other places a lot and have a short trailer.
John M
/ What is the major difference? #11
Excellent advice.I would put no more than than 2 horses on 3 acres.Divide into 2 paddocks and rotate when one gets eaten down.You won't have much to mow.You will be amazed at how quickly 1 acre will be stripped and trampled.
It wouldn't be possible to use all three acres for the horses. I was planing on splitting the paddoks in half for rotating the horses. I should point out that I don't have any horses now. I'm just trying to plan my purchases for the future. The 3pt finish mower seems the no brainer way to go. I plan on mowing weekly and don't plan on leaving it on my machine. Thanks for all the insiteful replies.
Matt T.:D
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59914)
2025 PJ CC162 T/A...
20' One Trip Shipping Container (A66285)
20' One Trip...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2022 EZ-GO ELITE...
