What is the John Deere Shaft Key M84552 used for?
   / What is the John Deere Shaft Key M84552 used for? #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
59" Snow Blower Connection Question??
Hi,
Can someone tell me if all I need to connect my 4310 driveshaft coupler to the gear box on my 59" snow blower is a single cap bolt or hex bolt? I was told I need a key??? Where would a "key" be used or fit in this application? My photo shows the cap screw as mentioned in the manual by the red arrow. What grade cap screw/bolt should this be? Could a sheer bolt/pin be used, but in my case, they break too easily.
FredSG
   / What is the John Deere Shaft Key M84552 used for? #2
JD parts shows a key for the input shaft of the snow blower, P/N M84550 which is a 1/4" square x .992 long key. I would check and see if the input shaft is machined for a key. It's possible at some point the key was eliminated and that machining step removed to save money. If your input shaft is machined for a key, I would use one.
The bolt is 5/16-18 x2" Grade 5.
   / What is the John Deere Shaft Key M84552 used for? #3
The P/N you referenced, M84552 is listed as 1.366" long. Where did you get that P/N? JD parts list P/N M84550 for the 59" snow blower.
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
