What is the good Chainsaw for clearing?
   / What is the good Chainsaw for clearing? #101
Easy for me to get, just have to drive 4-5 hours each way...............
Lotsa corn here too, not much eatin kind though
   / What is the good Chainsaw for clearing? #102
In the proletarian states i live near such as Ma, RI and Conn, no choice for non ethanol at the pump. You can buy it at our local outdoor power equipment facility..$14 per gallon.
You can buy it at Walmart here, or at least you could before NonEthanol became available. I ran the E-10 without a problem for years, when I was running a saw every weekend; then flush it with a tank of the NE premix before putting the saw up. I did the same with my snowsleds; running cheap gas until spring, then putting a couple of tanks of Non ethanol through. My new sled takes 91 octane though, and most non ethanol is only 90.
   / What is the good Chainsaw for clearing? #103
I have little choice unless I want to pay $14 per gallon for non.
I have had to rebuild or replace just about every carb on my small engines.
I now run everything until it runs out of gas, drain the carbs and now i have no more kelloggs Corn Flakes in my carbs.
   / What is the good Chainsaw for clearing? #104
There is a chance that E-10 will be replaced with E-15 in a few years. Iowa is starting the ball to roll.
   / What is the good Chainsaw for clearing? #105
As I posted before, I am clearing several lots, and need a good chainsaw to tackle the bigger trees and can grind them down afterward with a stump grinder. But you really cant find out much of anything out of the stores on what works for solid pine and oak that we have down here. What is a good Chainsaw that starts on the first pull, lightweight but powerful, and doesnt breakdown after a day or two of heavy cutting..?
ECHO.I have 3 and all have been flawless ..
It can be but the longer you work the saw, the stronger your arms get. It got to the point for me that a Husky 372 was simply an extension of my arms. It became weightless after awhile.
If I had to recommend a saw for you saying you are in decent physical shape, it would be the Echo 590.
Put on a 20 " bar and you'll be good to go no matter what you'll confront.
Just quit when you're tired and build up to it gradually.
I once owned a JD 750 and currently a tractor commensurate size wise to your Kubota. I also logged professionally so I know how tough the woods can be on equipment.
I'm telling you that cutting down trees is one thing but if you think you're going to de stump your plots with either of these, you're in for a wake up.
I don't now how much land we're talking about here but a track hoe of some type might be a consideration. Would be much faster than a bulldozer because the hoe can dig out the stump, dig a hole beneath where the stump used to lay, and then bury the stump right there as opposed to going back and forth to keep pushing the mess toward a border line of some sort.
I think a Cat 310 would be more applicable than a Cat D-8 from what I've experienced with land clearing.
I ripped out some of the smaller stumps early yesterday, think may have to dig out with the backhoe, as they will 'wake you up' in the morning.
The ones that seem to fit the bill are the Stihl battery powered chainsaw with 36 volt battery and the Dewalt battery powered chainsaw with 60 volt battery, but curiously they are missing out of the inventory in the stores (they leave them out on the floor with no security, wonder where they went).
I finally decided to get the Dewalt 60 Volt Battery Powered Chainsaw, as the reviews on it were good, but it is very hard to find them in stock or the batteries. Not a good sign... Same thing with the Stihl, Echo, Husqvarna battery powered chainsaws, the stores/dealers advertised them, but either nothing in stock or missing even from display. Needed something as starting on some of the lots, so trying out the Ryobi Battery Powered Chainsaw, we shall see..
   / What is the good Chainsaw for clearing? #108
Let us know your thoughts on it once putting it to the test ...
   / What is the good Chainsaw for clearing? #109
I have a couple friends that have the Milwaukee 18V saw. They both love them. I have the Milwaukee weedeater and blower. Don't let the "little" 18v battery throw you off. They are super powerful. I would not expect to be able to run it all day on 1 battery but for intermittent work they would be great. I would hesitate to recommend a battery saw as primary for your project but they have their place.
I mostly use pro-type gas saws. My two main go-to saws are a Jonsered 2152 (50cc - the twin sister to a Husqvarna 353 technically not marketed as pro saws, but they have a magnesium case and other pro-type construction) and a Husqvarna 357 XP (just under 60cc). I'm cutting mostly hardwoods, but we don't have a lot of huge ones around here. The bulk of what I cut is in the 10"-18" range, and it's rare I'm dealing more than 24" DBH. I don't often have the need for a larger saw, and I'd carry one these smaller lighter saws and spend a bit more time on the occasional larger tree than carry around a larger saw that I don't need most of the day.
I had been wondering about battery-powered chainsaws for a while, following the reviews, and trying out those owned by friends. I was impressed with the Milwaukee M18 saw, so bought one a couple of years ago when I saw a good package deal on that and some other tools I needed. Given the good reviews and the fact that I already owned a bunch of Milwaukee M18 tools, it made a lot of sense for me. It's a decent little saw. I'd say it cuts as well as a decent 40cc gas saw. It will never be one of my primary saws, but it's handy for what it is.
One thing I have noted: the 12 Amp-Hour high output battery that Milwaukee sells with it will last a whole lot longer than a tank of bar oil, so you have to keep an eye on that. I may switch to using 6 or 8 A-H batteries to more closely match the bar oil tank capacity.
   / What is the good Chainsaw for clearing? #110
This is exactly my home owner situation. I am much aligned to your two with the Husq Rancher and the 257.
Felling is done with the 50cc w an 18" bar and blocking is done w the 257 and 16" bar.
Have had the Rancher since 1985 and the 257 since 1998. They start every year and have been trouble free. They are the only two saws I have never "swapped out" when i had the saw addiction.
The 353 was one of my favorite Husqs. More so than the 246. The 353 had some grunt to it as well as some speed.
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
2003 Big Tex 10PI...
2015 Toro Reelmaster 3 Gang Mower (A55851)
2015 Toro...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
