What is the good Chainsaw for clearing?
   / What is the good Chainsaw for clearing?
I've only had great luck with Husquavarna. My Stihl won't hold an idle since new. The shop where I bought it couldn't help and blamed it on the emission controls. Stick to the equipment dealers that specialize in chain saws, where tree professionals might go. The size is dependent on what weight you are comfortable working with. I'm older, so lightweight is what I need. My Husky 345 e-series with a 16" bar will cut anything I want to cut, even it takes me a little longer than someone who has a bigger saw. Watch a bunch of YouTube videos on how to safely fell a tree. I've done a lot of cutting and I still learn more from watching these videos.
Watch out when the tree hits the ground, as the heavy side can bounce. Almost caught my chin yesterday as I was dropping trees...
   / What is the good Chainsaw for clearing? #132
Kind of similar, Really like any of the 340,346, 350,353 saws.
Inherited dad's 2001 closed port Husky 350 and used it a couple years, but it developed a lean condition because of a leak between the clamshell haves.
Fixed the leak. Put a flat top meteor piston in, reduced the squish, muffler modded it and advanced the timing a couple degrees. With a an 18 inch bar and full chisel It cuts really quick and is light.
I liked it so well bought another runner Husky 350 off ebay an (open port) version, that had a fuel leak- fixed that, reduced the squish, muffler mod and modified an 8 tooth stihl drive hub to replace the stock 7 tooth.
Put a 16 inch bar, full chisel chain on it and it is a real gem to use on smaller stuff because of the higher chain speed. Going to get one of the super light bars for it to.
Get my son to help buck up firewood and with 2 saws things go quick.
Clamshell husky saws may not be all metal but being plastic they are light. For the bigger stuff I also have dads McCulloch Promac 700 and other than being Loud and having more vibration it really works well.
Figured that covered most bases but wanted a Big saw for any real large diameter trees I might need to cut.
For fun I bought a Stihl 660 Clone kit and am getting ready to play "build a saw".
Can't wait to have a large cc saw.
All that said the 350 Husky's will probably continue to be my go to saws.
Then again is there such a thing as having "to many" good running saws?:D
   / What is the good Chainsaw for clearing? #133
Well,it's been 8 yrs. since my last post and I'm sure you all missed me dearly. As for chainsaws. I have a Stihl 026, 034 , 441. My 034 is my favorite, a 54 cc. I bought it new over 30 yrs. ago and use it the most. I also bought 2 Echo's this spring, a 501P and a 620P. The The 501 and the 026 are just different. 026 is 22 yrs old and has a crankcase leak. I still run it for dropping popple. I planted 700 in 2007 and they are pretty much dead. The 026 cant keep up with the 501P, however, it is a crippled saw and old. The 026 does not have the speed, maybe cause of the leak, not sure and doesn't idle well but wide open it is pretty good, but the 501P is faster. I am sure the Stihl 261 is a better saw , but $150 more . The 501P does not have the better bar, it is a cheapy made in China and surely wont last, so it will cost me $50 for a new bar someday when the Stihl would last much longer. My 034 will out cut the 501P however, but is 8% more cc's. The 501 is bottom line pro saw ,but nice . My Echo 620P is quite a saw for the $600 with tax. It is 20% more cc than the 501 but will cut 50% faster. It's a very nice saw. Both Echo's were $1,000 with tax for the both. My Stihl 441 is a screaming saw . The 620P does not run with it in any way. Many dont like the 441 , but some say it has a lot of torque , and I agree. If I had to do it all over , I think I would have went with the Stihl 261 and not bought the 2 Echo's. Would have saved $350 and would have had an extra bar and chains from the 026. All are good saws, however , I think the Stihl 261 is a better quality saw than the 501P and the 261 is a true pro saw. I am not biased , for I love all saws. Hand saws, sawzalls, miter boxes, you name it, as long as they dont give me trouble and do it job. If I had to pick one saw, I think it would be the Echo 620P, unless I could have a new 034. The Stihl 441 is much easier on gas than the 620P and will cut noticably more wood with a gallon of gas and do it faster too. I bet the 261 computer carb is easier on gas than the Echo's too. It is likely the best bet out there for a one saw guy. The extra money for the Stihl? I say Pfft, quality is cheap.
   / What is the good Chainsaw for clearing? #134
A McCulloch Mac 10-10 will cut anything it can get it's chain into If you can carry one, or find one ;-)
But it;s hard to beat the little Husky 543XP ...
Are you big and strong? If not, a smaller saw does a lot of work... just a little slower.
If you are bucking on the landing, weight works in your favor ;-)
eta
By the way, I hear that the Makita chain saw is a heck of a good piece of equipment!.
Likely made by Singer sewing machine company or some such Euro groupe. ;-)
   / What is the good Chainsaw for clearing? #135
I bought the MS261 C-M last year,,
Since it's purchase, my other two Stihl saws have been cleaned, and put on the shelf, hopefully to never be run, again.
The 261 starts easy, weighs WAY less than my other saws, and has incredible power.
I was looking at the saws at the store one day, picked up the 261, and the low weight sold me instantly.
It has been a great purchase,, I do not say that about many things,, these days,,,
   / What is the good Chainsaw for clearing? #136
I like my 261 a lot but it burns wayyyy more gas than my 032AV or my buddies 271.
   / What is the good Chainsaw for clearing? #137
I can also say good things about a Stihl 261. Burns a lot of gas? I’ve not noticed that but even if it does the cost of fuel for a chainsaw is awfully small.
   / What is the good Chainsaw for clearing? #138
Two of ours have 60 inch bars.
   / What is the good Chainsaw for clearing? #139
If someone is looking at Ryobi, the direct tools outlet sometimes has better prices on blemished/reconditioned. Direct Tools Outlet Site
This chain saw brush cutter attachment for gas trimmers will zip through smaller trees, briars and brush like crazy. The nice thing is you can cut pretty close to ground level, and the trimmer shaft puts some distance between you and whatever you're cutting. But in my experience, it throws debris so wear eye protection. Also strongly recommend using a trimmer with handlebars to control it. Don't have any bystanders or pets anywhere near it. This is one tool to be very, very careful using. https://www.amazon.com/Forester-Cha...efix=chainsaw+brush+blade,aps,316&sr=8-3&th=1
   / What is the good Chainsaw for clearing? #140
I bought a similar blade, but, it is a carbide tipped 10" blade.
The blade is so thin, it goes through most woody plants and small trees effortlessly.
I guess it is similar to comparing a circular sawmill to a bandsaw. The thin bandsaw takes WAY less horsepower.
CATERPILLAR D6N LGP CRAWLER DOZER (A52707)
CATERPILLAR D6N...
2016 BOMAG BW 177D5 SMOOTH DRUM ROLLER (A52707)
2016 BOMAG BW...
Native American Wooden Head Statue (A55853)
Native American...
2014 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2014 Ford F-150...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
