What is the correct use of the decompression/compression release knob?
   / What is the correct use of the decompression/compression release knob? #21
A compression release is a great fall back in the event of a run away condition.
As small as these tractors are you can jump off one or open hood and stuff your shirt in the intake....but those are crazy times and I also would not want to be around one running away any longer than needed. I might throw the lever too!
   / What is the correct use of the decompression/compression release knob? #22
An additional use that nobody's mentioned: These tall narrow tractors were designed for tilling rice paddies. I wonder how many times one has gone into a hole, flopped over on its side, then later was cranked with compression released to get water out of the cylinders.
Photo I found on Yanmar-Japan's website.
497435d1486142145-2310d-starting-yanmarinternationalphoto2004-jpg
   / What is the correct use of the decompression/compression release knob? #23
I know, many old big generators used to have a hand pump, for prelube. You never see that anymore. Everything is just so disposible, and that's the way the manufacturers like it.
Right, disposable like our 40-45 year-old Yanmars and the 50s vintage Ford n models.
   / What is the correct use of the decompression/compression release knob? #24
Does the average oil pump even move any oil at cranking speed?
I made a prelube system for one of my generators, without success. I found it had to be quite a pump.
Well on my 2 Yanmars it makes a difference. I have installed an oil PSI gauge, and when cranking with the decompression lever pulled I can hear the oil start to be picked up by the pump and my gauge will start to climb, so I know its circulating the oil and building a little pressure prior to starting.
   / What is the correct use of the decompression/compression release knob? #25
The oil light on my old 2002D would go out in less than 2 seconds of cranking.
   / What is the correct use of the decompression/compression release knob? #26
Cranking and not starting? That is interesting.
   / What is the correct use of the decompression/compression release knob? #27
Will not start without releasing compression release. Was trying to illustrate oil pressure established by turning engine over with compression release before engine start.
   / What is the correct use of the decompression/compression release knob? #28
Thanks Winston, that is what I was trying to explain in my reply post about Industrial Toys question about the oil pump.
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2004 GMC Sierra 3500 Utility Flatbed Truck (A60460)
2004 GMC Sierra...
KUBOTA ZG23F ZERO TURN LAWN MOWER (A60430)
KUBOTA ZG23F ZERO...
2021 KUBOTA SVL75-2 SKID STEER (A60429)
2021 KUBOTA...
40' CONTAINER (A52706)
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
