What is the correct use of the decompression/compression release knob?
   / What is the correct use of the decompression/compression release knob? #21
A compression release is a great fall back in the event of a run away condition.
As small as these tractors are you can jump off one or open hood and stuff your shirt in the intake....but those are crazy times and I also would not want to be around one running away any longer than needed. I might throw the lever too!
   / What is the correct use of the decompression/compression release knob? #22
An additional use that nobody's mentioned: These tall narrow tractors were designed for tilling rice paddies. I wonder how many times one has gone into a hole, flopped over on its side, then later was cranked with compression released to get water out of the cylinders.
Photo I found on Yanmar-Japan's website.
497435d1486142145-2310d-starting-yanmarinternationalphoto2004-jpg
   / What is the correct use of the decompression/compression release knob? #23
I know, many old big generators used to have a hand pump, for prelube. You never see that anymore. Everything is just so disposible, and that's the way the manufacturers like it.
Right, disposable like our 40-45 year-old Yanmars and the 50s vintage Ford n models.
   / What is the correct use of the decompression/compression release knob? #24
Does the average oil pump even move any oil at cranking speed?
I made a prelube system for one of my generators, without success. I found it had to be quite a pump.
Well on my 2 Yanmars it makes a difference. I have installed an oil PSI gauge, and when cranking with the decompression lever pulled I can hear the oil start to be picked up by the pump and my gauge will start to climb, so I know its circulating the oil and building a little pressure prior to starting.
   / What is the correct use of the decompression/compression release knob? #25
The oil light on my old 2002D would go out in less than 2 seconds of cranking.
   / What is the correct use of the decompression/compression release knob? #26
Cranking and not starting? That is interesting.
   / What is the correct use of the decompression/compression release knob? #27
Will not start without releasing compression release. Was trying to illustrate oil pressure established by turning engine over with compression release before engine start.
   / What is the correct use of the decompression/compression release knob? #28
Thanks Winston, that is what I was trying to explain in my reply post about Industrial Toys question about the oil pump.
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
2006 GMC C5500 BUCKET /SIGN TRUCK (A59575)
2006 GMC C5500...
