what is the capacity of the hyraulics on 3200 cub
   / what is the capacity of the hyraulics on 3200 cub #1
jmt1271
Platinum Member
MO
Kubota L2501
what is the auxillary hydraulic pump capable of on my 3200 cub cadet tractor? lift capacity etc... thanks.
   / what is the capacity of the hyraulics on 3200 cub #2
Dont know the flow numbers but the Front can handle a snow thrower weighing about 300 lbs, with plenty more lift ability left (guess around 450 lbs) based on a few with johnny bucket setups. The rear 3pt can easyily handle a heavy 3 pt box blade (400- 500lbs)...
Hope that helps
   / what is the capacity of the hyraulics on 3200 cub #3
Hope that helps
   / what is the capacity of the hyraulics on 3200 cub #4
Do the 3K series have a seperate hydraulic pump? I thought the p-steering/ft/rear hydraulics tap off the hydrostatic drive unit.
Joel
   / what is the capacity of the hyraulics on 3200 cub #5
Joel
   / what is the capacity of the hyraulics on 3200 cub #6
The 3k series has a Hydraulic Steering Pump off the transaxle. It is separate from the hydro drive unit. It appears that the steering pump also drives the lift cylinder(s). Somebody can correct me if I'm wrong about this.
Bob B.
   / what is the capacity of the hyraulics on 3200 cub #7
Bob B.
   / what is the capacity of the hyraulics on 3200 cub #8
All of the auxillary hydraulic functions of the Cub Cadets (lift, power steering, remotes, ect) are powered by the charge pump for the hydrostatic pump system. A seperate pump to run these functions was never used.
   / what is the capacity of the hyraulics on 3200 cub #9
   / what is the capacity of the hyraulics on 3200 cub #10
</font><font color="blue" class="small">( All of the auxillary hydraulic functions of the Cub Cadets (lift, power steering, remotes, ect) are powered by the charge pump for the hydrostatic pump system. A seperate pump to run these functions was never used. )</font>
Section 10 of the Series 3000 Technical Handbook shows pictures of the Removal and Replacement of the Hydraulic Steering Pump. It shows pressure lines from the Charge Pump to Steering Pump and Steering Pump to both Front and Rear of Steering Cylinder.
This is the Cub Cadet 3000 Series Char-Lynn 2 Series Steering Control.
Bob B.
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
378811 (A51573)
378811 (A51573)
1998 WABA Van Trailer (A53117)
1998 WABA Van...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
