What is the 'best' wood splitter wedge design?
   / What is the 'best' wood splitter wedge design? #22
   / What is the 'best' wood splitter wedge design? #23
It certainly will. Do you guys think a 5" bore cylinder will be adequate? That should be about 49,000 pounds at 2500 psi. Hopefully I'll be able to get the pressure higher.
No, a 5" wouldn't be enough (unless you had a 5,000 psi system). I know because I have a similar head on my splitter with a 5" cylinder. My head only has a horizontal plate that then cleaves the bottom half 3 additional ways. With the right sized log I can get 3 pieces of wood on every pass. The pictured head is splitting it several more times. If the wood is well seasoned I can generally push it through on high. A knot will kick it into low. Even green box elder will cause the splitter to bog down. I've never jammed it, but my neighbor broke my splitter when he was trying to force a 3' diameter elm stump through it. Idiot.
Anyways, I really like the design because it produces very uniform pieces, but it does create quite a bit of trash. Generally I'll pick through the trash pile and save the splinters and shavings because they work great for a fire starter. Even with a 22gpm pump (you can now get bigger 2 stage pumps) and a 5" cylinder it takes 4 people to run the machine at full throttle. One person brings the logs to the station, an operator loads the log and works the controls and two people stack.
   / What is the 'best' wood splitter wedge design? #24
I have been planning a new splitter build the last couple of years.Mine is 27 yrs old,works great in the single vertical split mode but when I put the 4 way on it leaves quite a bit to be desired when I hit knotty wood.I was going to switch out to a 5" cylinder for the time being to give it some more oomph.But since it is close to the ground you need to work in the stoop over mode which gets old after awhile.My new one will be a combo Timberwolf and some of my own features.But I also have been worried about optimum wedge type.All the demos have straight grain oak.So I will be watching threads and posts on wedge design also.
That's kinda my plan. A combo of the timberwolf with my own features. I currently plan on using an adjustable height 4 way wedge.
   / What is the 'best' wood splitter wedge design? #26
w
hile my splitter build is currently on hold, here is a pic of the wedge I will be using. 1017161503.jpg and the rams to push the wood thru it.1210151640.jpg
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
