What is the best way to measure out fluids from a bulk container?
   / What is the best way to measure out fluids from a bulk container? #1
acohen100
Southern Vermont
Kubota BX24
I bought a few bulk buckets of various lubricants and made my first attempt at using them changing my front axle fluid yesterday. First I tried measuring by pouring it into smaller, one liter containers through a funnel but that was just a major pain in the ***. Then I tried pouring directly into the tractor through a funnel and it overflowed covering half my garage floor with oil. I figured that there has got to be an easier way to do this.
   / What is the best way to measure out fluids from a bulk container? #2
They make various sizes of bulk dispensers for this. Most are open topped so you can fill them easily, then have a bottom dispensing spout so you never have to tip it.
McMaster Carr sells them. I'm sure dozens of other places do, too.
   / What is the best way to measure out fluids from a bulk container? #3
They also make barrel pumps...
Soundguy
   / What is the best way to measure out fluids from a bulk container? #4
   / What is the best way to measure out fluids from a bulk container? #5
I don't know what size container you are using but all large liquid containers should poured with the fluid coming out the top hole ? this even looks confusing.. take a rectangular paint thinner can for instance, there is only one cap and one place for liquid to come out, open cap and pour with opening at top and that will make the glug-glug go away and give you a nice smooth pour, it may sound ( not-right ) but try it :D
   / What is the best way to measure out fluids from a bulk container? #7
Go to any parts store, they have hand pumps that replace the top of a 5 gallon pail. They are not that expensive. I saw them in use at the local GM dealer on 5 gallons pails of synthetic gear lubes. They tech had the pail right under the beer truck he was filling with lube and pumping into the axle.
here is one in action YouTube - Hand-Operated 5-Gallon-Pail Lubricant Pump
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
Caterpillar Loader Quick Coupler (A55218)
Caterpillar Loader...
2014 Dodge 5500 4X4 Bucket Truck (A55218)
2014 Dodge 5500...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
