What is the best oil to use in a brush hog?
   / What is the best oil to use in a brush hog? #1
Homeboy929
Ford 4600
Which oil weight is best for a Bush hog
   / What is the best oil to use in a brush hog? #4
Running 80-90 gear oil Oreilly store brand in mine. Zero problems , changed maybe every 5 years with 50hrs/yr.
   / What is the best oil to use in a brush hog? #5
If the output shaft is leaking you can also use corn head grease which is basically a #0 or #00 semi-fluid grease.
I think you'll need to search for Spindle Grease or Flowable Grease, but 2nd this is the seals are old.
   / What is the best oil to use in a brush hog? #6
I run 80w-90 gear oil in mine. It's got all the right additives for that type of friction & seals.
   / What is the best oil to use in a brush hog? #9
Corn head, Spindle, 00 grease is known by several names and is fast becoming the lubricant of choice for gear boxes (especially old ones) since it will flow and keep everything lubricated. But most importantly will not leak as readily as regular gear oil. I use it in all my gear boxes old and new.
   / What is the best oil to use in a brush hog? #10
What I am hearing is there are two options. Pack it with grease if the seals are bad; use gear oil if the seals are good. Downsides are oil leaks and greases cavitate. Does anyone use a mixture?
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
Carnival Ticket Booth (A51691)
Carnival Ticket...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
