Homeboy929
- Joined
- May 18, 2023
- Messages
- 1
- Tractor
- Ford 4600
Which oil weight is best for a Bush hog
I think you'll need to search for Spindle Grease or Flowable Grease, but 2nd this is the seals are old.If the output shaft is leaking you can also use corn head grease which is basically a #0 or #00 semi-fluid grease.
That's what I run in the Ford 917L flail mower. Even 120 weight gear oil runs out, the seals are so bad.Cotton Picker Spindle Grease 00
