What is the best oil to use in a brush hog?
   / What is the best oil to use in a brush hog? #1
Homeboy929
Ford 4600
Which oil weight is best for a Bush hog
   / What is the best oil to use in a brush hog? #4
Running 80-90 gear oil Oreilly store brand in mine. Zero problems , changed maybe every 5 years with 50hrs/yr.
   / What is the best oil to use in a brush hog? #5
If the output shaft is leaking you can also use corn head grease which is basically a #0 or #00 semi-fluid grease.
I think you'll need to search for Spindle Grease or Flowable Grease, but 2nd this is the seals are old.
   / What is the best oil to use in a brush hog? #6
I run 80w-90 gear oil in mine. It's got all the right additives for that type of friction & seals.
   / What is the best oil to use in a brush hog? #9
Corn head, Spindle, 00 grease is known by several names and is fast becoming the lubricant of choice for gear boxes (especially old ones) since it will flow and keep everything lubricated. But most importantly will not leak as readily as regular gear oil. I use it in all my gear boxes old and new.
   / What is the best oil to use in a brush hog? #10
What I am hearing is there are two options. Pack it with grease if the seals are bad; use gear oil if the seals are good. Downsides are oil leaks and greases cavitate. Does anyone use a mixture?
2017 Ram 4500 Bucket Truck (A55218)
2017 Ram 4500...
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
TMA (A49461)
TMA (A49461)
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
