What is the best 2 cycle oil?
   / What is the best 2 cycle oil? #1
Gobblin Tom
Western, PA
2011 JD 2520
After reading some of the post on my Stihl chainsaw, it got me wandering what everyone thinks which 2 cycle mix is the best? I always run high test in my equipment, do you? So let's see what everyone says!!!
   / What is the best 2 cycle oil? #2
Texas Refinery Corporation makes a high quality 2 cycle oil for air cooled two cycle engines.
   / What is the best 2 cycle oil? #3
I use Stihl Ultra. full synthetic. Much less coking than anything else I have tried. Use the best quality fuel as well watch the octane.
   / What is the best 2 cycle oil? #4
I use the Stihl Ultra HP synthetic oil and 89 octance gas.
   / What is the best 2 cycle oil? #6
Tom, I typed it backwards. Instead of Ultra HP, it's HP Ultra.:laughing: Costs a little more, but for the amount I use, I figure it's worth it. It comes in a 6 pack, but my dealer keeps a pack open and will sell individual bottles; enough for one gallon of gas. There are actually several different Stihl 2-cycle oils and as mentioned by others, you can double your warranty by using the HP Ultra, although it's too late for me.:laughing: Of course in the 6 years I've worked my string trimmer hard, it's never been back to the dealer.
   / What is the best 2 cycle oil? #7
Stihl Ultra for me too.
Any time I buy gas that goes into a container, I get premium and give it a double dose of Sta-Bil.
I never used stabil, I guess I will have to start!!! Using a double dose can you mess anything up?
   / What is the best 2 cycle oil? #9
I don't think a double dose could ever hurt anything. I probably don't use a full double dose, but I do make sure I use a full dose and a little more each time.:laughing:
   / What is the best 2 cycle oil? #10
I'm also a Stabil user -- the marine formula (blue, not red) is designed for gasoline that has ethanol, so that's the right stuff. Premium gasoline, because some of it goes in the chainsaw, and always name-brand oil: stihl, jonsereds, etc.
My understanding is the little bottles of 2-cycle have fuel stabilizers, but I still think using Stabil is a good idea. I've got no particular expertise, by the way!
2014 DRAGON 130 BBL VACUUM TRAILER (A58214)
2014 DRAGON 130...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
2020 Komatsu D155AX-8 Crawler Dozer, S/N 100205, PIN# KMT0D126PJC100205, Turbo Diesel Engine, 13' (A59076)
2020 Komatsu...
XCMG CV83PD (A53317)
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
set of 4 tractor trailer tires Roadforce (A56435)
set of 4 tractor...
