Re: What is that high-pitched noise when I try to lift something too heavy with the 3pt?
Ok so here is the update:
I started out by draining the trans/hydraulic fluid into a bucket which had a hole in it, therefore spilling about 1/2 a gallon on to the floor of my barn.
Got some FRESH cat litter and put it on the floor. Need a little more, but oh well.
Swapped buckets. Drained the remaining oil.
Next, I started to remove the filter. At least I thought it was the filter. Apparently it was some random part at the rear of the tractor that I was removing bolts too. After I found that it did not come off easy, I got my manual for the US version of my tractor. Whoops, tightened those bolts back up. Found the actual filter, removed it, washed it off, replaced it.
Enter stage left curse words.
I learned about 17 new ways to string curse words together trying to get that last bolt on top of the line that runs into the filter on. Since my tools, my floor, and my hands were all covered in tras/hyd. fluid, my hands were slipping, I kept dropping my socket wrench, the tool that looks like a screwdriver but that you can put sockets on kept running into the brake linkage, etc etc. Finally managed to get it back on there. Hope I didn't cross-thread anything too bad
Grabbed my bucket of fluid that the previous owner gave me. Stuck my funnel in the fill and happily emptied the remaining fluid in the bucket into my tranny. Later I learned that the resivour requires 2.5 gallons of fluid instead of whatever I was dumping in there. It reads about 1/8th to 1/4" of an inch over the full mark now.
Anyway, started the tractor, pulled on the lever to make the carryall come up. Nothing happend. Kept holding it, thankfully it came up, system must have just had to prime. Drove outside of the barn, checked the fluid, still above full. Drove over to the log to try to pick it up. Same EEEEEEEEEEEKing sound. Listened to it carefully, was NOT coming from the pump on the front of the engine, it was coming from the rear of the tractor near all the hydraulic lift stuff in the rear. Guessing its just a relief valve.
Well, at least I have changed my fluid now.
PLEASE READ THIS IF NOTHING ELSE!
Do I need to drain the tras/hyd. fluid so that it is below the full mark on the dipstick? It is about 1/8th to 1/4th of the way over the full mark with the tractor running in neutral. I know sometimes having a little extra isn't a bad thing, but at the same time I don't want to harm anything.
Well, what is the noise coming from the rear? Relief valve as I had suspected or something else?
Thanks!
Dennis
